Arcsin(x) for x > 1 in fortran
Zhiyong_b_
In fortran there exists a intrinsic function ASIN for calculating arcsine(x).
But there is one problem, x should be real and less than 1 or complex.
But my problem is I have to calculate arcsin(x) for real number x lager than 1.
How can I solve this?
skinner__karl
Isn't arcsin(x) only defined for -1<=x<=1 ?
Simon_Geard
In F2008 the following should work:
program main
   complex :: x, y
   x = cmplx(2,0)
   y = asin(x)
   print *,y
end program main
but you'll probably need a v15 compiler for that. The above doesn't build with Version 14.0.3.202.
mecej4
Zhiyong B. wrote:
But my problem is I have to calculate arcsin(x) for real number x larger than 1. How can I solve this?
No real number y exists for which x = sin(y) > 1. In geometrical terms, no point on a circle falls outside the square that just circumscribes the circle.
You can solve 'this' by reviewing your mathematics books.
JVanB
Valued Contributor II
If you want to keep it real, recall that
sin(a+b*i) = sin(a)*cos(b*i)+cos(a)*sin(b*i)
= sin(a)*cosh(b)+i*cos(a)*sinh(b)
so let a = sign(pi/2,x), b = acosh(abs(x)), then sin(a+b*i) = sign(real(1,kind(x)),x)*abs(x)+i*(0)*(don't care) = x
Thus you can test whether abs(x) > 1 and if so you know asin(x) = cmplx(sign(pi/2,x),acosh(abs(x)),kind(x))
jimdempseyatthecove
This depends on how x is bunged-up. If it is a rounding error
if(x<-1.0) x=-1.0
if(x>1.0) x=1.0
y=asin(x)
Or if x is accumulation of cyclical use mod
y = asin(mod(x+1.0-TINY(x), 2.0) - 1.0)
The issue with the above is when x is exactly 1.0, you would end up with 1.0-TINY(x)
Jim Dempsey
Zhiyong_b_
Thanks anyway. I have solved this problem. In fact, there exists x=sin(y) >1 with y a complex number.
Here is my code for solution:
complex function arcsin(x)
	real x
        complex I = (0.0, 1.0)
	if (abs(x) >= 1) then
		arcsin = -I*log(I*x + I*sqrt(x**2 -1))
	else
		arcsin = ASIN(x)
	end if
end function
