29617 Discussions
Array Initialization Error when mixing different integer types.
Michael_B_10
Code:
PROGRAM main
  USE ISO_C_BINDING
  IMPLICIT NONE
  INTEGER, PARAMETER :: DIM0 = 7
  INTEGER, PARAMETER :: DIM1 = 4
  INTEGER, PARAMETER :: num_flags = 4
  INTEGER(kind=8), PARAMETER :: DIM0a = 7
  INTEGER(kind=8), PARAMETER :: DIM1a = 4
  INTEGER, DIMENSION(1:3) :: dim_qf_data =(/DIM0,4,num_flags/)
  INTEGER(kind=8), DIMENSION(1:2) :: dims = (/DIM0a,DIM1a/) ! #1
  INTEGER(kind=8), DIMENSION(1:2) :: dims = (/DIM0,DIM1/) ! #2
  print*,dim_qf_data
   print*,dims
END PROGRAM main
When I use #1 it prints correctly:
7,4,4
7,4
But when I use #2 it prints dim_qf_data's second array value wrong:
7,0,4
7,4
For Intel 14.0 it was correct for both. It also works correctly on Mac and Linux with Intel 15.0 (and 14.0).
Computer system env. attached.
That's just weird.  Thanks, we'll look into it.
Escalated as issue DPD200366575. I will let you know of any progress. Thanks again.
This has been fixed in our sources - I have asked that the fix be included in 15.0 Update 3 - it probably will.
The fix is now scheduled for Update 3 (May.)
Michael_B_10
Thanks for fixing this so fast and keeping me updated.
