Array PARAMETERs
John4
Valued Contributor I
When I try to compile the code below with the -stand switch, I get a warning stating that the array expressions do not conform. Am I doing something wrong? Thanks.
[cpp]module mod1
    !ifort -c -stand mod1.f90
    integer, parameter :: IDENTITY(2, 2) = RESHAPE([1, 0, 0, 1], [2, 2])
    integer, parameter :: DKR(2, 2) = IDENTITY
end module mod1[/cpp]
It's a compiler bug - I can see that it's already fixed in our internal sources. I'm not sure when the fix will appear.
