29652 Discussions
Array bounds and shape checking fails to detect runtime errors, ifort 2021.4.0 Build 20210910_000000
Mike_D_5
Is there a fix for this?
Array bounds and shape checking fails to detect runtime errors in all but the simplest assignment cases. Any operations on the RHS seem to disable checking even though the operations are returning mis-matched arrays. All these demonstrator cases are detected correctly by gfortran with the -bounds-check option. Failure to detect these errors slows down development and discourages use of the intel compiler.
Demonstration:
ifort -o trya2d_c -check shape trya2d_c.f90
./trya2d_c
  SHAPE(htau) 100 100
  L/UBOUND(htau) 2 2 101 101
  SHAPE(gphit) 102 102
  L/UBOUND(gphit) 1 1 102 102
This line is not detected as a shape mismatch even with -check shape at compilation:
htau(:,:) = MAX( 0.5, MIN( 30., 45.* ABS( SIN( 3.142/180. * gphit(:,:) ) ) ))
Even though the shapes do not match:
  100 100 102 102
  Note: this error is detected correctly by gfortran with -bounds-check
In fact, a simple operation with the RHS prevents shape checking:
 A: htau(:,:) = 1.0 * gphit(:,:) 102 102
 B: htau(:,) = gphit(:,:) * 1.0 102 102
Only a simple assignment is trapped correctly:
 C: htau(:,:) = gphit(:,:) 102 102
forrtl: severe (408): fort: (33): Shape mismatch: The extent of dimension 2 of array HTAU is 100 and the corresponding extent of array GPHIT is 102
Image PC Routine Line Source
trya2d_c 0000000000406F8F Unknown Unknown Unknown
trya2d_c 0000000000404370 Unknown Unknown Unknown
trya2d_c 0000000000403852 Unknown Unknown Unknown
libc-2.17.so 00002ADBAFD7E555 __libc_start_main Unknown Unknown
trya2d_c 0000000000403769 Unknown Unknown Unknown
Demonstrator program:
cat trya2d_c.f90
REAL, ALLOCATABLE, DIMENSION(:,:) :: htau, gphit
ALLOCATE(htau(2:101,2:101), gphit(102,102))
WRITE(*,*) ' SHAPE(htau)     ', SHAPE(htau)
WRITE(*,*) ' L/UBOUND(htau)  ', LBOUND(htau), UBOUND(htau)
WRITE(*,*) ' SHAPE(gphit)    ', SHAPE(gphit)
WRITE(*,*) ' L/UBOUND(gphit) ', LBOUND(gphit), UBOUND(gphit)
write(*,'(a)') 'This line is not detected as a shape mismatch even with -check shape at compilation: '
write(*,'(a)') 'htau(:,:) =  MAX(  0.5, MIN( 30., 45.* ABS( SIN( 3.142/180. * gphit(:,:) ) ) ))'
write(*,'(a)') 'Even though the shapes do not match: '
write(*,*) SHAPE(htau), SHAPE( MAX(  0.5, MIN( 30., 45.* ABS( SIN( 3.142/180. * gphit(:,:) ) ) )))
write(*,'(a)') '  Note: this error is detected correctly by gfortran with -bounds-check '
write(*,'(a)') 'In fact, a simple operation with the RHS prevents shape checking: '
write(*,*) 'A: htau(:,:) = 1.0 * gphit(:,:) ', SHAPE(1.0 * gphit(:,:))
write(*,*) 'B: htau(:,) = gphit(:,:)  * 1.0 ',SHAPE(gphit(:,:)  * 1.0)
htau(:,:) =   gphit(:,:)  * 1.0
write(*,'(a)') 'Only a simple assignment is trapped correctly: '
write(*,*) 'C: htau(:,:) = gphit(:,:) ',SHAPE(gphit(:,:))
write(*,*) 'D'
end
Barbara_P_Intel
This runtime error is not yet fixed in the internal releases. I filed a bug report, CMPLRLLVM-40141. I will post when a fix is implemented.
Mike_D_5
Hello, has there been any further work done on this bug.. CMPLRLLVM-40141?
Barbara_P_Intel
I checked the status. No fix yet.
Barbara_P_Intel
NOW there's a fix! In the latest 2023.2.0 release from July, the shape mismatch is detected.
