Array initialization in block
Greg_Thoreson
I found that I cannot initialize an array inside of a BLOCK statement using Intel fortran 16.0.3.207. Is this an unsupported feature, or a bug? Here's the minimal code that reproduces the error:
program testblock
    implicit none
    block
        integer, dimension(4) :: array = (/1,-1,1,-1/)
    end block
end program testblock
And here's the error message I receive:
Intel(R) Visual Fortran Compiler for applications running on IA-32, Version 16.0.3.207 Build 20160415
Copyright (C) 1985-2016 Intel Corporation.  All rights reserved.
101004_2045
catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances
in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for testblock.f90 (code 1)
I can easily fix it by doing this instead:
program testblock
    implicit none
    block
    end block
But it took me a while to track down that issue and I thought others may be curious.
It's a bug. Fixed in 17.0.
