Array of polymorphic objects
OP1
New Contributor III
Just graduated to IVF 11.1.070 and trying towrap my head around some of the new concepts related to polymorphism.
Is it possible to declare an allocatable array of components, where each component belongs to the same class but could be of different types within that class?
In pseudo code:
Declarea parent type P.
Extend P with child types C1 and C2.
Declare an allocatable array of objects of class P.
Allocate each element of P to the proper type (C1 or C2).
Thanks for any help on this - or for pointers to useful reference examples/material.
Olivier
Steven_L_Intel1
Yes, this is possible. But I strongly recommend using a more recent compiler as we have fixed many issues with polymorphism since 11.1.
Andrew_Smith
Valued Contributor I
Steve, could you show an example as I can not see how this would work as you describe without some additional structure. Simple arrays must all be the same type I think even if the type is extended.
Steven_L_Intel1
Andrew,
The request was for an array of components - which I took to mean an array of derived type. Here's an example.
[fortran]    program PolyArray
    implicit none
    type basetype
    end type basetype
    type, extends(basetype) :: exttype1
    end type exttype1
    type, extends(exttype1) :: exttype2
    end type exttype2
    type arraytype
        class(basetype), allocatable :: comp
    end type arraytype
    type(arraytype), dimension(3) :: ary
    integer :: i
    allocate (basetype::ary(1)%comp)
    allocate (exttype1::ary(2)%comp)
    allocate (exttype2::ary(3)%comp)
     do i=1,3
        select type (st=>ary(i)%comp)
        type is (basetype)
            print 101,i,"basetype"
        type is (exttype1)
            print 101,i,"exttype1"
        type is (exttype2)
            print 101,i,"exttype2"
        class default
            print 101,i,"unknown"
        end select
  101    format ("The dynamic type of ary(",i0,")%comp is ",A)
        end do
    end program PolyArray[/fortran]
and when I build and run this I get:
[plain]The dynamic type of ary(1)%comp is basetype
The dynamic type of ary(2)%comp is exttype1
The dynamic type of ary(3)%comp is exttype2[/plain]
For some odd reason the forum is removing the 101 label on the format - grr. If you "View Plain" it should be there.
Andrew_Smith
Thanks Steve, that is similar to the way I have tackled it i.e by containing the polymorphic components inside a common wrapper object
OP1
New Contributor III
Yes, thanks Steve for your example - this is what I was looking for.
Olivier
