Arrays
Intel_C_Intel
In the code below FillArray2 doesn't work. Why is A(*) equivalent to A(1:*) but not equivalent to A(:)?
Code:
PROGRAM TestArray
	IMPLICIT NONE
	! Variables
	INTEGER*4, ALLOCATABLE :: Array1(:)
	INTEGER*4, ALLOCATABLE :: Array2(:)
	! Body of TestArray
	ALLOCATE(Array1(5))
	ALLOCATE(Array2(5))
	Array1 = 0
	Array2 = 0
	CALL FillArray1(Array1)
	CALL FillArray2(Array2)
	DEALLOCATE(Array1)
	DEALLOCATE(Array2)
END PROGRAM TestArray
SUBROUTINE FillArray1(Arr1)
	INTEGER*4, INTENT(INOUT) :: Arr1(*)
	INTEGER*4 nCount
	DO nCount = 1, 5
		Arr1(nCount) = nCount
	END DO
RETURN
END
SUBROUTINE FillArray2(Arr2)
	INTEGER*4, INTENT(INOUT) :: Arr2(:)
	INTEGER*4 nCount
	DO nCount = 1, 5
		Arr2(nCount) = nCount + 10
	END DO
RETURN
END
(:) in an argument is a different beast called "assumed shape" and requires extra information to be passed by the caller (a descriptor) and an explicit interface is required. (*) and (1:*) is "assumed size" where the upper-bound is not provided and the program is required to make sure that it does not index outside of the passed-in array elements.
