29597 Discussions
Assignment of an allocatable to an allocatable
IanH
When using the F2003 lhs (re)allocation of arrays in assignment feature (and /assume:realloc_lhs), can the left hand side array be not allocated prior to the assignment?
Under 11.0.061 with /check:all this blows up with an "attempt to fetch from ... not allocated" error, so maybe not?
[cpp]PROGRAM Allocation
  INTEGER, ALLOCATABLE :: starting(:)
  INTEGER, ALLOCATABLE :: finishing(:)
  INTEGER i
  ALLOCATE(starting(10))
  !ALLOCATE(finishing(1))
  starting = [ (i, i = LBOUND(starting, 1), UBOUND(starting, 1)) ]
  finishing = starting
  WRITE(*,100) 'starting', starting
  WRITE(*,100) 'finishing', finishing
  WRITE(*,*) UBOUND(finishing)
  100 FORMAT(A20,1X,10(I4,1X,:))
END PROGRAM Allocation
[/cpp]
If I uncomment the ALLOCATE(finishing(1)) statement it seems to work. But distinguishing between an array that is not allocated versus an array that is allocated to the wrong size seems a bit of a picky requirement for the feature.
The code above also seems to work if I make starting explicit shape (ie. INTEGER :: STARTING(10) and delete the relevant allocation statement), or if I put the finishing=starting assignment in a subroutine with the right hand side being an assumed shape argument, all of which confuses me as to what is legitimate and what is not.
IanH
It turns out that the earlier issue I remembered was slightly diffrerent from this and is fixed in 11.0, but your test case is still broken. I have reported this to the developers and is our issue DPD200110210. The workaround is to not use /check:pointer and /assume:realloc_lhs together.
This is an error in the /check:pointer diagnostic test. If you turn that off, it works. I think we have another report of this already, but if not, I'll let the developers know.
IanH
Thanks for the clarification.
This problem will be fixed in a version to be released later this year.
IanH
It appears that the new 11.1 release (or maybe earlier) contained a fix for this. But while experimenting with the new (eagerly awaited, bye bye iso_varying_string...) deferred length character F2003 feature:
[cpp]PROGRAM DeferredLengthChar
  CHARACTER(LEN=:), ALLOCATABLE :: test
  ! Should be automatically allocated to length of expression
  test = 'Hello there'
  WRITE (*,100) test
  100 FORMAT('"',A,'"')
END PROGRAM DeferredLengthChar[/cpp]
With /assume:realloc_lhs /check:all /warn:all I get a similar "Attempt to use pointer ..." error. If I take out the /check:all or put in a dummy ALLOCATE(CHARACTER(1)::test) statement then things "appear" to work, so I presume this is just the runtime diagnostic still playing up, rather than me exceeding the extent to which deferred length strings have been implemented?
Yes - this is check:pointer not being informed of this new feature. Further, /assume:realloc_lhs ought not to be required in this case. I'll pass it on to the developers. Thanks. Issue IDs are DPD200137145 and DPD200137146.
