29376 Discussions
linking against a "dummy" shared library
gregfi04
My codebase is split up into groups of subroutines that offer separate functionality, but ultimately make use of the same data set. I'd like to be able to compile each group of subroutines into a shared library, and then have the ability to customize the distribution on a per-user group basis. My thought is to compile a set of "dummy" libraries to satisfy the executable at runtime and gracefully exit the program. Is there any reason why this shouldn't work?
Here's an example of the code I'm using for the dummy library:
subroutine subroutine1
USE MODULE1
USE MODULE2
implicit none
write(*,*) 'ERROR: THIS MODULE IS NOT PRESENT'
write(*,*) 'IN THIS DISTRIBUTION OF THE CODE.'
stop
end subroutine subroutine1
I'm compiling the shared library with the following command:
ifort -g -O0 -CB -fpic -shared -i-static -module ../../build -o libdummy.so dummy.f90
However, when I try to run the executable (after properly setting $LD_LIBRARY_PATH), I get the following:
./code: symbol lookup error: ./code: undefined symbol: for_concat
Thoughts?
Greg
TimP
Quoting - gregfi04
USE MODULE1
USE MODULE2
implicit none
stop
The -i-static option looks like a problem here. I think you would want to leave the linking of Intel run-time libraries until the final link, rather than attempting to link bits of them statically into each of your libraries, even if you are restricting the final link to static only.
gregfi04
Quoting - tim18
Thanks, got it to work.
I took the "-i-static" out of the linker commands for the shared libraries, and included "-static-intel" in the final link statement. However, now it needs /opt/intel/fc/10.1.015/lib to be in $LD_LIBRARY_PATH. Is there any way around that?
