29251 Discussions
Attaching files to comments on threads
bearoflittlebrain_ol
After finding the excellent article "How to customiize dialog box colors using subclassing" by Anthony Richards, I did some work on it and, wrote a comment and tried to attach files to my response. Thank you Steve for explaining that this is currently not allowed: only on the original posting.
This is a severe limitation on discussion where the devil may be in the detail, because I must post a new thread in order to continue the discussion. In addition, probably very few will have seen the response because it has not appeared on the first page ofpostings in this forum.
Bear of little brain
Jugoslav_Dujic
Valued Contributor II
Testing... It seems to work for me?
Jugoslav,
I think someone has changed things - it looks as if the problem is solved. Testing also.
Bear
What you tried to do, Bear, is attach files to a comment on a Knowledge Base article. Those are not in the forums. As I replied there, you can attach files here in the forum.
