Avoiding Repeat counts in NAMELIST file ouptput
Karthee_S_
I am using the following compiler version intel/compiler/64/14.0/2013_sp1.2.144. In writing namelists to a file, the compiler writes repeat counts of elements in an array. How do I avoid it? For example the ouput file (modified.nml) from the "program io" contains
&MY_BUNDLE NUMBOOKS        =           7, INITIALISED     = T, NAME    = 'julliet                                           ', VEC     = 4*2.000000
whereas i am expecting
&MY_BUNDLE NUMBOOKS        =           7, INITIALISED     = T, NAME    = 'julliet                                           ', VEC     = 2.000000, 2.000000, 2.000000, 2.000000
Please find the test program I used.
program io
  implicit none
  ! local variables, all left without values assigned
  integer, parameter    :: strlen = 50  ! convenient & flexible
  integer               :: numBooks
  logical               :: initialised
  character(len=strlen) :: name
  real, dimension(4)    :: vec
  integer               :: ios          ! for checking status
  ! group variables into a namelist called 'example_nml'
  namelist /my_bundle/ numBooks,initialised,name,vec
  ! open the input file containing the data
  open(unit=56,file='input.nml',status='old',iostat=ios)
  if (ios /= 0) then
     print*,'ERROR: could not open namelist file'
     stop
  end if
  ! read data into the declared namelist
  read(UNIT=56,NML=my_bundle,IOSTAT=ios)
  if (ios /= 0) then
     print*,'ERROR: could not read example namelist'
     stop
  else
     close(56)
  end if
  write (*,*) "=====Variables read from file have values:====="
  write (*,*) numBooks
  write (*,*) name
  write (*,*) initialised
  write (*,*) vec
  ! modify values 'programatically'
  numBooks = 7
  initialised = .true.
  name = 'julliet'
  vec = (/2.0, 2.0, 2.0 , 2.0/)
  ! open a new file for writing
  Open(unit=56, file='modified.nml', form='FORMATTED', delim='APOSTROPHE', carriagecontrol='NONE')
iF (ios /= 0) then
     print*,'ERROR: could not open new namelist file'
     stop
  end if
  ! now write the modified data
  write(UNIT=56,NML=my_bundle,IOSTAT=ios)
  if (ios /= 0) then
     stop
  else
     close(56)
  end if
  write (*,*)
  write (*,*) "=====modified values written to modified.nml, compare the files====="
end program io
Steven_L_Intel1
We don't provide an option to avoid the repeat counts. This is a Fortran standard behavior. Why are you "expecting" the value to be repeated? The output you get is processed properly by NAMELIST input.
Karthee_S_
The output files containing NAMELIST are read by unix scripts for post processing (which cannot read repeat counts).
For Cray/SGI compilers we can use ASSIGN environment
 CALL ASNFILE (fname,astring,ier)
to suppress repeat counts. Do we have similar functionality in INTEL?
Steven_L_Intel1
We don't provide the ability to suppress repeat counts. We do have various attributes that can be controlled through environment variables, but that's not one of them. I'll comment that NAMELIST output has a LOT of flexibility in what the "processor" does and it's not surprising that a script written for one compiler doesn't work in another.
Karthee_S_
Many thanks.
jimdempseyatthecove
You should be able to easily write a script file to expand the repeat counts and run that as the first step of your post processing.
Steve, my read of Karthee's post is it is a non-Fortran application or script that is performing the post processing, and Karthee wanted a quick fix. Someone reading this may be willing to suggest a simple AWK or Python script that parses lines into tokens, passes all tokens excepting for tokens of the format n*whatWouldBeAToken, then emit the corrected string inclusive of commas.
Jim Dempsey
Steven_L_Intel1
I understood Karthee's problem - but there is no quick fix. Karthee's script relies on implementation-dependent formatting.
