BIND(C) and !DEC$ ATTRIBUTES C
Martin__Paul
I have a Fortran project with calling convention CVF specified in project properties, which I understand equates to stdcall except CVF passes scalars by reference. Fortran calls a C++ function which uses cdecl. I am using BIND(C) attribute which I am assuming defaults to cdecl. If I change the C++ convention to stdcall, do I have to declare !DEC$ ATTRIBUTES REFERENCE, STDCALL, ALIAS: 'Init' :: Init in the function block, or is there an alternative to BIND(C) which works for stdcall?
We do not allow the use of ATTRIBUTES STDCALL with BIND(C). If you are calling STDCALL routines, you'll need to use ATTRIBUTES to specify everything as you show it.
Martin__Paul
Thank you for the swift response!
