James
I have the same problem - a BLOCK_DATA (called ATMOS) defined in a static library with another SUBROUTINE that externs it like this
EXTERN
I have the same problem - a BLOCK_DATA (called ATMOS) defined in a FORTRAN source compiled into static library with another SUBROUTINE that externs it like this:
EXTERNAL ATMOS
I also tried:
EXTERNAL BLOCK DATA ATMOS
When I run my program the common block initialized by the ATMOS block data unit is empty. All data is ZERO.
The EXTERN statement does not seem to be helping here - are there more details I might be missing? I am linking these FORTRAN libraries from a Win32 Console Application - not a FORTRAN console application - maybe that is the problem?
Thanks Steve -I don't have the latest patches installed - I'll give that a try. I cannot get it to link any which waywith IVF 8.0 out of the box - so hopefully it is fixed in a patch. I'll post a message when I get the patch installed.
cheers
