29487 Discussions
[BUG] overriding deferred private procedure of abstract type defined in separate module raises error
SebastianM
I found a strange bug, present in all ifort ifx version I tried (2023.2.0 - 2025.1).
This fails to compile:
module abc
  type, abstract :: abc_example
  contains
    procedure(print_func), deferred, private :: print
    generic :: write => print
  end type abc_example
  ! interface
  abstract interface
    subroutine print_func(this)
      import :: abc_example
      class(abc_example), intent(in) :: this
    end subroutine print_func
  end interface
end module abc
module implement
  use abc, only: abc_example
  type, extends(abc_example), public :: example
  contains
    procedure, private :: print => print_example
  end type example
contains
  subroutine print_example(this)
    class(example), intent(in) :: this
    print*, "WORKS"
  end subroutine print_example
end module implement
program test_abc
  use implement, only: example
  type(example) :: my_example
  call my_example%write()
end program test_abc
with this error:
$ ifx fail_intel.f90
fail_intel.f90: error #8322: A deferred binding is inherited by non-abstract type; It must be overridden.   [PRINT]
fail_intel.f90(17): error #6136: Derived-type declared must be ABSTRACT   [EXAMPLE]
compilation aborted for fail_intel.f90 (code 1)
The error can be prevented in two (strange) ways:
1. remove the `private` attribute from the deferred print method.
2. having `abc_example` and `example` in the same module (moving `abc_example` into `implement` works)
Xiaoping_D_Intel
We can confirm that it isn't a compiler bug. ifx is exhibiting the correct behavior in issuing an error for this. A private component is inaccessible when the parent type is use associated.
Xiaoping_D_Intel
A bug report has been opened for it.
WileyOne
I am (mostly) sure this is not a bug; I've attempted to do this before and - per my reading of the standard - it's not allowed. Private procedures are only accessible (including the ability to override them) within the appropriate scope (that module and its submodules). There is no exception given for deferred procedures. That means that only child classes living in the host module or its submodules can overwrite private deferred procedures. If the child class lives in a separate module, then the deferred procedure must be public. This matches exactly what you're seeing. The relevant sections of the 2018 standard are 14.2.2 and 7.5.5.9.
Xiaoping_D_Intel
SebastianM
Thank you for the investigation. The original issue was an implementation for an equal comparison method, that was then used for the "==" operator:
procedure(equal_if), private, deferred :: equal
generic, public :: operator(==) => equal
Here it makes totally sense, that the equal is private, since the operator should be used. Problem then is, that an implementation can only be in the same module. So in the end I would say, I dislike this language decision and it may is hard to debug, since the abstract type can be used, but not extended in a foreign module.
JohnNichols
Honored Contributor I
module implement
  contains
  ! interface
  abstract interface
  end interface
  contains
  end type example
contains
    print*, "WORKS"
program test_abc
Only one change required not two
