29641 Discussions
Bad variable initialization in block causes ICE
IanH
Sometimes I forget what is permitted and what is not.  This is non-conforming code (says F2008 7.1.12p2), but ifort perhaps got more confused than it should.
PROGRAM MentalBlock
  IMPLICIT NONE
  BLOCK
    INTEGER :: array(2) = SIZE(array)
  END BLOCK
END PROGRAM MentalBlock
>ifort /check:all /warn:all /standard-semantics "2016-02-07 MentalBlock.f90"
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0 Build 20151021
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
101004_2042
catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in
 which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for 2016-02-07 MentalBlock.f90 (code 1)
A variant, that perhaps is conforming...
PROGRAM MentalBlockDeluxe
  IMPLICIT NONE
  BLOCK
    DIMENSION :: array(2)
    INTEGER :: array = SIZE(array)
  END BLOCK
END PROGRAM MentalBlockDeluxe
>ifort /check:all /warn:all /standard-semantics "2016-02-07 MentalBlockDeluxe.f90"
101004_2042
compilation aborted for 2016-02-07 MentalBlockDeluxe.f90 (code 1)
Thanks - I will send this off to the developers.
Escalated as issue DPD200381580. Interestingly, if the declaration is not within a BLOCK the compiler accepts it, but shouldn't.
A further update. This usage is not standard F2008 but will be standard in F2015 (paper 15-194), which carved out an exemption for initialization expressions. I've asked our developers to make sure that standards warnings are handled appropriately for this.
The ICE will be fixed in the final 17.0 release later this year.
