- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
I am a beginner level programmer in Visual Fortran. I am currently learning Fortran on Visual Studio Professional 2012 with Intel Visual Fortran XE 2013.
For the very first time, debugging works assuming the codes don't have any errors. However, I am getting an error showing "Field does not exist" when debugging the same code for a second time. The code works only for the first time again if I close the program and reopen it. I don't know what is the problem as I have no prior experience.
Any help would be appreciated. Thank you.
- Marcas:
- Intel® Fortran Compiler
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I'm not familiar with that message. Would you please attach a screenshot of the VS window and the message?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Very strange. The first screenshot is not showing that you have started the debugger yet. Does this message appear only when you click the Start button to start debugging?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Strange indeed! No, this message appears regardless if I clicked the start button or the debugger. You are correct on the observation that the debugger hasn't started yet. Again, this happens only when I try to run the code second time after one successful debugging.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Did your Aitivirus delete or sandbox the executable?
Jim Dempsey
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
No. I can see the executable in the debug file. It shows the successful debug result when clicked.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
This is a VS error. You might try Googling for this error.
Did you happen to copy the Solution and/or Project file from one system to another (possibly containing a newer or different version of VS or Operating System)?
This message (my hypothesis) is originating from one of the VS IDE XML or VB scripts requesting a member data field by name to a field that does not exist... on the current platform (that which you are running on).
Try creating a new solution (on the system exhibiting the error), and copy/paste the text content of your program.
Jim Dempsey
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I tried Googling for the error and came up empty.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
visual studio "field does not exist"
The above line, typed as-is, yields 26,500 hits for me.
Jim Dempsey
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Yes, but the only one that seems relevant links to this thread. Most of them are about Excel.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Rafi, do you click a button or select a menu item to make this error appear? This was not clear to me. What are the steps you follow to get this error?
Does it happen if you create a new project of type Console Application > Main Program Code?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
It appears when I want to run the program second time, as in if I click the debug (F5) button. So steps are following:
Open new project> write code>debug>runs successfully (assuming no syntax errors) first time> click debug again> "field does not exist"
Now, if I save this project> close the program >open again>debug> runs first time> click debug second time>"field does not exist"
It happens for the Console Application>main program code as well.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thanks. Please do this and let me know if it fixes the problem (or not):
- Uninstall Intel Parallel Studio XE
- Delete the folder C:\Program Files (x86)\Microsoft Visual Studio 11.0\Intel Fortran (it may already be gone)
- Reinstall Intel Parallel Studio XE
If this doesn't solve the problem I will escalate this to the developers.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thanks Steve. I did uninstall and reinstall as you asked me to. It did not solve the problem.
When I tried running a new project in visual basic, just to check whether it is a visual studio problem, it showed the same error. So Jim Dempsey was right. This error might not be associated with Visual Fortran XE at all. However, I haven't found the solution yet.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Do you have any plugins added to Visual Studio? Try this. In VS, select Tools > Options > Environment > Add-In Security. Uncheck the box "Allow Add-In components to load" and click OK. Close and reopen VS. Does the problem persist?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Yes, it still shows the same error
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Truly weird. And I have done more web searching and can't find any reference to this message as worded.
In Visual Studio, click Help > About. Then click Copy Info. Paste the result into a reply here.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Microsoft Visual Studio Professional 2012
Version 11.0.61030.00 Update 4
Microsoft .NET Framework
Version 4.5.50938
Installed Version: Professional
LightSwitch for Visual Studio 2012 04938-088-0011822-02551
Microsoft LightSwitch for Visual Studio 2012
Office Developer Tools 04938-088-0011822-02551
Microsoft Office Developer Tools
Team Explorer for Visual Studio 2012 04938-088-0011822-02551
Microsoft Team Explorer for Visual Studio 2012
Visual Basic 2012 04938-088-0011822-02551
Microsoft Visual Basic 2012
Visual C# 2012 04938-088-0011822-02551
Microsoft Visual C# 2012
Visual C++ 2012 04938-088-0011822-02551
Microsoft Visual C++ 2012
Visual F# 2012 04938-088-0011822-02551
Microsoft Visual F# 2012
Visual Studio 2012 Code Analysis Spell Checker 04938-088-0011822-02551
Microsoft® Visual Studio® 2012 Code Analysis Spell Checker
Portions of International CorrectSpell™ spelling correction system © 1993 by Lernout & Hauspie Speech Products N.V. All rights reserved.
The American Heritage® Dictionary of the English Language, Third Edition Copyright © 1992 Houghton Mifflin Company. Electronic version licensed from Lernout & Hauspie Speech Products N.V. All rights reserved.
Visual Studio 2012 SharePoint Developer Tools 04938-088-0011822-02551
Microsoft Visual Studio 2012 SharePoint Developer Tools
ASP.NET and Web Tools 2012.3.41009
Microsoft Web Developer Tools contains the following components:
Support for creating and opening ASP.NET web projects
Browser Link: A communication channel between Visual Studio and browsers
Editor extensions for HTML, CSS, and JavaScript
Page Inspector: Inspection tool for ASP.NET web projects
Scaffolding: A framework for building and running code generators
Server Explorer extensions for Windows Azure Web Sites
Web publishing: Extensions for publishing ASP.NET web projects to hosting providers, on-premises servers, or Windows Azure
Intel(R) Visual Fortran Package ID: w_fcompxe_2013.1.119
Intel(R) Visual Fortran Composer XE 2013 Update 1 Integration for Microsoft Visual Studio* 2012, 13.0.3600.11, Copyright (C) 2002-2012 Intel Corporation
* Other names and brands may be claimed as the property of others.
NuGet Package Manager 2.8.50313.31
NuGet Package Manager in Visual Studio. For more information about NuGet, visit http://docs.nuget.org/.
PreEmptive Analytics Visualizer 1.0
Microsoft Visual Studio extension to visualize aggregated summaries from the PreEmptive Analytics product.
SQL Server Data Tools 11.1.20627.00
Microsoft SQL Server Data Tools
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thanks. One thing you have that I don't is the Visual Studio Spell Checker Extension. I wonder if that's the issue. Go to Tools > Options > Extensions and remove the spell checker (I think that's where it would be.)
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
It would be nice (MS VS feature) if the error message, presumably issued running a tool, or attempting to launch a tool, would indicate where (which component) the error occurred. e.g. "Visual Studio Spell Checker Extension reports: Field 'someName' does not exist". This would certainly aid in problem diagnosis (and resolution).
Jim Dempsey
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
