29649 Discussions
Best way to do an alias for a function/subroutine
carlls
Greetings all:
In converting libraries over to F90/F2003 I am finding some duplication of routines, and I am wondering about the best way to do it....
Let's say I have two functions Uppr and StrUpCase, both take in a string and return it as upper case. Let's assume I am going to take StrUpCase as being my "golden" source.
I could write a wrapper so
FUNCTION Uppr(string)
Uppr=StrUpCase(string)
RETURN
END FUNCTION UPPR
But this seems "a bit wasteful" is there a STANDARD way to equivalence functions/subroutines like you do variables?
Carl
There isn't a standard way to do this. Well, almost. Here's one that works if both routines are in a module.
Let's assume that StrUpCase is a module procedure. In the part of the module before CONTAINS, add this:
[cpp]interface Uppr
module procedure StrUpCase
end interface[/cpp]
Now if code calls Uppr it will actually call StrUpCase and you don't need to duplicate the code or write a jacket. What this does is define a generic interface named Uppr. In most cases, one would have two or more module procedures listed, but there's no requirement for that.
If the routines themselves are not in a module but you have explicit interface blocks for them, you could fudge this with some !DEC$ directives but I don't want to lead you down that path.
carlls
Thanks Steve.
Once again your wisdom saves allot of time and recoding.
Carl
