Big endian - Little endian swapping
onkelhotte
New Contributor II
Hi there,
Im in the process to connect one of my programs to a Siemens S7 system. The communication takes place via Winsocket and TCP/IP. The connection is being made and I get data... But they are in the wrong order.
For example, I get an integer(kind=2) for the actual month. I would have expected a 2 for February, but I get 512. In binary it is
00000010 000000 which is 512,
00000000 000010 would be 2
The bytes are swapped, the big - little endian issue.
Is there an easyway to turn them into the right way? I get some real(kind=4) values as well.
Thanks in advance,
Markus
onkelhotte
New Contributor II
After searching the net, I found that the function MVBITS does exactly what I need...
[bash]CALL IMVBITS( intIn,  8, 8, intOut, 0 )
CALL IMVBITS( intIn,  0, 8, intOut, 8 )[/bash]
This is for integer(kind=2). For real(kind=4) you have to do this:
[bash]      INTEGER                                       :: i_element
      INTEGER                                       :: i_element_br
! Transfer 32 bits of realIn to generic 32 bit INTEGER space:
      i_element = TRANSFER( realIn, 0 )
! Reverse order of 4 bytes in 32 bit INTEGER space:
      CALL MVBITS( i_element, 24, 8, i_element_br, 0  )
      CALL MVBITS( i_element, 16, 8, i_element_br, 8  )
      CALL MVBITS( i_element,  8, 8, i_element_br, 16 )
      CALL MVBITS( i_element,  0, 8, i_element_br, 24 )
! Transfer reversed order bytes to 32 bit REAL space (realOut):
      realOut = TRANSFER( i_element_br, 0.0 )[/bash]
Thanks to David Stepaniak, he wrote this code!
Markus
I've seen some C code samples that use masks and shifts, which might be more efficient. But if the speed of the MVBITS is sufficient, then use that.
Paul_Curtis
Valued Contributor I
Here is a routine I use for rearranging the byte-order in Modbus communications. There is a regrettable lack of standardization in Modbus, so my driver has a flag which can be set to match the byte-ordering convention of various devices. Since the device response is read into a character buffer, the swapping is done bytewise prior to interpretation as a number.
[bash]!   byte-order repacking
RECURSIVE FUNCTION RealByteOrder (buf1, flags) RESULT (buf2)
    IMPLICIT NONE
    INTEGER, INTENT(IN)             :: flags
    CHARACTER(LEN=4), INTENT(IN)    :: buf1
    CHARACTER(LEN=4)                :: buf2
    !   rearrange byte-order for REALs; only
    !   one of these bitflags will be set for
    !   a given device
    !   little-endian
    IF      (BTEST(flags, modbus_FPL)) THEN
        buf2(1:1) = buf1(4:4)
        buf2(2:2) = buf1(3:3)
        buf2(3:3) = buf1(2:2)
        buf2(4:4) = buf1(1:1)
    !   big-endian byte-swapped
    ELSE IF (BTEST(flags, modbus_FPBB)) THEN
        buf2(3:3) = buf1(4:4)
        buf2(4:4) = buf1(3:3)
        buf2(1:1) = buf1(2:2)
        buf2(2:2) = buf1(1:1)
    !   little-endian byte-swapped
    ELSE IF (BTEST(flags, modbus_FPLB)) THEN
    !   big-endian (Intel default)
    ELSE
         buf2 = buf1
    END IF
END FUNCTION RealByteOrder
[/bash]
onkelhotte
New Contributor II
I get appr. 200 values every 2 seconds, so I think that the use ofMVBITS should be okay.
Paul, thanks for the code, maybe I will implement it and measure, which method will be faster. But what is the difference between two two byte swapped branches? They do the same but in another order.
Markus
