OMP task, Access violation
jansson
If I run this program I do not get what I expect.
1)
If I use the ALLOCATABLE declaration+ allocation I get the Access violation.
2)
The other declaration do not fill G with the values expected.
What do I do wrong?
I use ifort 2011 update 8 and VS2010
How do I get the nice code formating I seen elsewhere?
Thanks for comments!
/Magnus
program Console_parallel_test
use OMP_lib
implicit none
integer i,tasks_total
! double precision G(1000,4)
double precision, ALLOCATABLE :: G(:,:)
tasks_total=1000
ALLOCATE(G(tasks_total,4))
G(1,1)=34.0D0
!$OMP parallel default(none) shared(tasks_total)
!$OMP master
do i=1,tasks_total
!$OMP task default(none) firstprivate(i) shared(G)
G(i,2)=dble( OMP_GET_THREAD_NUM() )
G(i,3)=OMP_GET_wtime()
G(i,1)=33.0D0
G(i,4)=OMP_GET_wtime()
!$OMP end task
enddo
!$OMP end master
!$OMP end parallel
continue
end program Console_parallel_test
jimdempseyatthecove
Try adding shared(G) to the !$OMP parallel.
Note, the default(none) should have made access to G invalid (bug)
>>How do I get the nice code formatting I seen elsewhere?
There is a icon that looks like a pencil/highlighter. Click on that, select the formatting from a drop-down window (C++), paste in your text.
Jim Dempsey
jansson
I tried to add G to the shared but still get the same problematic behaveour in both cases.
[bash]   !$OMP parallel default(none) shared(tasks_total,G)[/bash]
Cheers,
Magnus
jansson
I simplified the above further and made three very similar programs of which one work as I expect.
The only change between them was in the kind of array used.
Which one would you expect to work? My own guess was wrong!
Pointer Array:
[fortran]  program Console_parallel_test
    use OMP_lib
    implicit none
    integer i
    double precision, pointer :: G(:)=>null()
    allocate(G(1000))
    G(1)=10001.0D0
!$OMP parallel default(none) shared(G,i)
!$OMP master
   do i=1,1000
       G(i)=i
!$OMP end task
   enddo
!$OMP end master
!$OMP end parallel
   continue
    end program Console_parallel_test[/fortran]
Allocatable Array:
    use OMP_lib
    implicit none
    integer i
    double precision, ALLOCATABLE :: G(:)
    ALLOCATE(G(1000))
    G(1)=10001.0D0
!$OMP master
   do i=1,1000
       G(i)=i
!$OMP end task
   enddo
!$OMP end master
!$OMP end parallel
   continue
non-dynamic Array (Assumed-size Array?):
    use OMP_lib
    implicit none
    integer i
    double precision G(1000)
    G(1)=10001.0D0
!$OMP master
   do i=1,1000
       G(i)=i
!$OMP end task
   enddo
!$OMP end master
!$OMP end parallel
   continue
For me the one using a pointer worked as I expect, not the other ones.
If I remove the TASK construct they all work.
Is this a bug some one could reproduce or a feature?
Magnus
pbkenned1
Both the allocatable array and static array versions reveal Intel compiler bugs. Jim said:
Therein lies the rub...some bug with default(none). Just remove the default(none) clauses, and the program will run correctly. I made that modification, and printed out the last array element as a sanity check:
C:\U102891>diff U102891_alloc.f90 U102891_alloc_no_dflt.f90
< !$OMP parallel default(none) shared(G,i)
> !$OMP parallel shared(G,i)
< !$OMP task default(none) firstprivate(i) shared(G)
> !$OMP task firstprivate(i) shared(G)
> print *,'G(1000) = ',G(1000)
You also need to tell the linker extra stack is needed (/F:20000000):
C:\U102891>ifort -V
Intel Visual Fortran Intel 64 Compiler XE for applications running on Intel 64, Version 12.1.2.278 Build 20111128
C:\U102891>ifort -Od -Qopenmp U102891_alloc_no_dflt.f90 /F:20000000
-stack:20000000 <<
C:\U102891>U102891_alloc_no_dflt.exe
G(1000) = 1000.00000000000
C:\U102891>
I'll report this to the developers. I didn't check the static allocation version, but suspect the same bug with default(none).
Patrick Kennedy
Intel Developer Support
pbkenned1
The tracking number for this defect is DPD200178853. I'll keep this thread updated with news from the developers.
I confirmed the static version has the same bug. I don't know why the pointer version doesn't also, unless it's just masked by something.
Patrick
jimdempseyatthecove
Patrick,
Good initiative on following up on the default(none) bug.
Jim Dempsey
jansson
Hi Patrick,
Thanks for the workaround removing default(none). I would never have tried that one by myself.
I look forward to download the fixed version since I depend on TASK for my project, and I LOVE default(none).
Thanks!
/Magnus
