29279 Discussions
Blank common problem for DEBUG compiler
mushroom89_
Several of my programs subdivide blank common into real*8, real*4, and integer*4 arrays. The RELEASE compiler runs the programs fine. The DEBUG compiler compiles, but then hits an execution error when it runs because the first m subscript exceeds m(1). These are the lines after declaring common (900000). real*8 d real r integer m common d(1),r(1),m(1) Common is then subdivided into arrays where the entry points are tracked based on word length. It works, except for DEBUG. Is there a work-around for this? Is it a compiler error?
It is not a compiler error. The Debug configuration turns on array bounds checking. Your program deliberately accesses arrays out of bounds so you will have to disable that option under "Run time".
