29657 Discussions
Bogus error with PROTECTED attribute
Harald
there is a strange problem when the PROTECTED attribute is used before the actual variable declaration.
Example:
module ifc_protected
  implicit none
  private
  public :: x
  protected :: x  ! Error here
  real      :: x
  protected :: x  ! OK here
end module ifc_protected
With the Intel v15 compiler I get:
% ifort -V -c ifc_protected.f90
Intel(R) Fortran Compiler XE for applications running on IA-32, Version 15.0.5.223 Build 20150805
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
FOR NON-COMMERCIAL USE ONLY
 Intel(R) Fortran 15.0-1818
ifc_protected.f90(6): error #6406: Conflicting attributes or multiple declaration of name.
compilation aborted for ifc_protected.f90 (code 1)
Commenting out the first PROTECTED makes the error go away.
Harald
Kevin_D_Intel
Thank you for reporting this. I submitted it to Development.
(Internal tracking id: DPD200376539)
