FORTRAN IO OPERATION
Madhubalan_R_
Hi all I am using the following code to create a new file PROGRAM TEST_IO INTEGER*4 UNIT,IOS OPEN (UNIT=119, FILE = '$HOME/compile.log', IOSTAT = IOS, - STATUS = 'NEW', RECL = 132, FORM = 'FORMATTED', - RECORDTYPE = 'VARIABLE', ORGANIZATION = 'SEQUENTIAL', - CARRIAGECONTROL = 'FORTRAN') PRINT *,IOS END PROGRAM Here HOME(/home/my_name) is an environment variable.When I execute this code I am always getting the IOS as 46.Without using a function to get the value of the environment variable, Can I solve this issue?
mecej4
You should not expect Fortran (or C, etc.) to do symbol substitutions or globbing in the same manner that we expect the Linux shell to do. You can call a library function to obtain the values of environment variables. See https://software.intel.com/en-us/node/526226; you can do
USE IFPORT
character(len=50) :: buf
call getenv('HOME',buf)
OPEN (UNIT=119, FILE = trim(buf)//'/compile.log', IOSTAT = IOS,
mecej4
USE IFPORT
Madhubalan_R_
Thanks you so much.
FortranFan
USE IFPORT
Standard Fortran subroutine (i.e., intrinsic procedure) GET_ENVIRONMENT_VARIABLE would now be preferable over an Intel extension of getenv:
See https://software.intel.com/en-us/node/580640.
With GET_ENVIRONMENT_VARIABLE, one does not need to include "USE IFPORT" statement.
jimdempseyatthecove
One caveat on the suggestion is if the environment variable 'HOME' is not specified, then the filename '/compile.log' places the log file in the root directory. It might be better to test buf for all blanks and/or with trailing '/'.
BUF = ADJUSTL(BUF)
IF(BUF.EQ.' ') THEN
  BUF = './'
ELSE
  IF(BUF(LEN_TRIM(BUF):LEN_TRIM(BUF)) .NE. '/') BUF = TRIM(BUF)//'/'
ENDIF
Consider adjusting the above to handle '\' as separator.
Jim Dempsey
