Bounds remapping for pointer (error # 6731)
abhimodak
May be this is a known issue ...
The program below does not compile. For the first three cases (see below), the compiler gives the bounds correctly; however there is a problem when pointer bounds are remapped. Compilation is aborted with error # 6731: Object is not a pointer object.
I am using 11.1.038 on WinXP64 with VS2005.
Abhi
Program Test_PointerPartition
! Purpose: Test bounds remapping for pointers.
Implicit None
Real(8), Target :: A(11:20)
Real(8), Pointer :: B(:)
B => A(11:20)
print *, LBOUND(B), UBOUND(B)
B => A
B => A(:)
! This remapping fails with 11.1.038
B(51:) => A(11:20)
End Program Test_PointerPartition
Kevin_D_Intel
I did not find any existing report of this. I forwarded to the Development team and will update the post when I know more.
(Internal tracking id: DPD200138689)
(Resolution Update on 06/11/2011): This defect is fixed in the Intel Fortran Composer XE 2011 initial release.
Kevin_D_Intel
Pardon the delayed update. This defect is fixed in the Intel Fortran Composer XE 2011 initial release.
ILIAS_T_
I experience the same problem. Is there any way to go around this?
Thanks in advanced.
Steven_L_Intel1
Ilias, it is likely you have a different problem, unless you are using a four-year-old compiler. Please start a new thread and attach a copy of a test program that demonstrates the problem and tell us which exact compiler version you are using and which compiler options you used.
ILIAS_T_
I am using an even older version :). Version 9.1.3250.2005. So the problem is the same as in the first post. I do not use any special compiler flag.
Steven_L_Intel1
You need to update the compiler. It was a compiler bug that has been fixed for a couple of years at least. Version 9.1 is going on six years old.
