Break on underflow
tmcole
I seem to remember that it is possible to get CVF to break on the offending line when encountering an underflow, but I can't remember exactly how to do it. Can this be done?
Project..Settings..Fortran. Under Floating Point, change Floating Point Exception Handling from 3 to 0. Under Run Time, check Floating Point Underflow.
Steve
tmcole
Thanks Steve - you are a scholar and a gentleman.
tmcole
Steve,
I finally got back around to implementing this, and it doesn't work. I get an error message regarding floating underflow, but it does not stop program execution and leave me on the offending line. Any other suggestions?
Hmm. Ok, in the debugger, select Debug..Exceptions. Change the action for floating underflow to "Stop Always". Run program.
Steve
tmcole
In case anyone else wants to use this valuable feature, you have to be interactively debugging a program for the "debug" button to appear.
