29435 Discussions
Broken Link for 2016 Redistributables
schulzey
All the download links for the 2016 redistributable library packages on the https://software.intel.com/en-us/articles/redistributables-for-intel-parallel-studio-xe-2016-composer-edition-for-windows​ page seem to be broken. Is there an alternative page that has these downloads?
Yuan_C_Intel
Hi, Schulzey
I just tried the download links. They all works for me.
Could you access this hyperlink for example?
https://software.intel.com/sites/default/files/managed/27/47/ww_icl_redist_msi_2016.0.110.zip​
schulzey
Hi Yolanda,
​Yes, I can access the link you provided. I have tried all the links on the https://software.intel.com/en-us/articles/redistributables-for-intel-parallel-studio-xe-2016-composer-edition-for-windows page again and it seems like the 2016 Update 2 and Update 3 links are the ones that are broken. All the others work.
​Peter
Yuan_C_Intel
andrew_4619
schulzey wrote:
Hi Yolanda,
​Yes, I can access the link you provided. I have tried all the links on the https://software.intel.com/en-us/articles/redistributables-for-intel-par... page again and it seems like the 2016 Update 2 and Update 3 links are the ones that are broken. All the others work.
​Peter
i can confirm those links are broken for me also. Update 4 works OK. Unless the is some specific issue whey not use update 4 as it should be backwardly compatible....
schulzey
Yolanda I can't access the two links you provided. I am trying to match the redistributable with the compiler version and need Update 2. It is for a client who confirms that the link is broken too. I don't know if Update 4 would be compatible, but I would prefer to get Update 2 if possible.
Kevin_D_Intel
I find the links to all C++ and Fortran Updates 1, 2, & 3 on this page are broken at the moment. We are looking into this, please stand-by.
Kevin_D_Intel
The links have been repaired. Our apologies for the inconvenience.
schulzey
Great thanks! They are working for me now.
