All the download links for the 2016 redistributable library packages on the https://software.intel.com/en-us/articles/redistributables-for-intel-parallel-studio-xe-2016-composer-edition-for-windows page seem to be broken. Is there an alternative page that has these downloads?
Hi, Schulzey
I just tried the download links. They all works for me.
Could you access this hyperlink for example?
https://software.intel.com/sites/default/files/managed/27/47/ww_icl_redist_msi_2016.0.110.zip
Hi Yolanda,
Yes, I can access the link you provided. I have tried all the links on the https://software.intel.com/en-us/articles/redistributables-for-intel-parallel-studio-xe-2016-composer-edition-for-windows page again and it seems like the 2016 Update 2 and Update 3 links are the ones that are broken. All the others work.
Peter
Hi, Peter
Could you try below two links for 2016 Update2 and Update 3. They still work from my side:
https://software.intel.com/sites/default/files/managed/b6/a6/ww_ifort_redist_msi_2016.2.180.zip
https://software.intel.com/sites/default/files/managed/46/54/ww_ifort_redist_msi_2016.3.207.zip
schulzey wrote:
Hi Yolanda,
Yes, I can access the link you provided. I have tried all the links on the https://software.intel.com/en-us/articles/redistributables-for-intel-par... page again and it seems like the 2016 Update 2 and Update 3 links are the ones that are broken. All the others work.
Peter
i can confirm those links are broken for me also. Update 4 works OK. Unless the is some specific issue whey not use update 4 as it should be backwardly compatible....
Yolanda I can't access the two links you provided. I am trying to match the redistributable with the compiler version and need Update 2. It is for a client who confirms that the link is broken too. I don't know if Update 4 would be compatible, but I would prefer to get Update 2 if possible.
I find the links to all C++ and Fortran Updates 1, 2, & 3 on this page are broken at the moment. We are looking into this, please stand-by.
The links have been repaired. Our apologies for the inconvenience.
Great thanks! They are working for me now.
![](/skins/images/8B6E2C8F64F54CBD7F7262AA46F575DA/responsive_peak/images/icon_anonymous_message.png)
