29386 Discussions
Bug: Cray Pointer to character (Intel Fortran 8)
nick2911
Intel Fortran Compiler 8
Using cray pointers gives a bug in the following:
character grp(1)
pointer (pgrp, grp)
pgrp = malloc(2)
call subroutine(grp)
BUT (with all other code identical)
call subroutine(grp(1))
works.
This bug only affects pointers to character variables, all others are OK.
This is not a complete program, so I can't tell what you think is wrong. If I complete it in a plausible way, it seems to work fine for me. What bad behavior do you see?
nick2911
Thanks for the reply. Complete (small) program:
program test
character grp(1)
pointer (pgrp, grp)
pgrp = malloc(2)
grp(1) = 'a'
grp(2) = 'b'
call test2(grp)
end
subroutine test2(grp)
character grp(*)
write(*,*) grp(2)
return
end
This fails to write grp(2) correctly. Replacing grp by grp(1) in subroutine call does work.
Works for me. What compiler version are you using?
nick2911
Version 8.0 (non-commercial version, downloaded 19/6/04).
Running on Fedora core 2 (IA32), kernel 2.6.6
Thanks for trying it!
That doesn't tell me the actual version.
Do an
ifort -what
and tell me the result. My guess is that you downloaded the initial release from December and didn't get the current one. This is a flaw in the way we do the non-commercial and evaluation kits. You have to register with Premier Support and download from there.
There's a proposal to update the initial download kits on a quarterly basis. I hope it happens, as the current situation is frustrating for many.
nick2911
Sorry! 'ifort -what' just gives 'no files specified ' etc..
ifort -V gives: Version 8.0 Build 20031016Z Package ID: l_fc_p_8.0.034
Ok, thanks. -what should work, though.
You indeed have the original December release. Please register with Premier Support and download the current version. You will need two downloads - first, l_fc_pc_8.0.046 - uninstall ifort and install this one. Then there is a patch, l_fc_pc_8.0.046_pe047.1, which installs on top of that.
nick2911
OK. Thanks very much indeed for your time.
Obviously, I appreciate that Intel have no obligation at all to make evaluation or free software available. However, given that it is there, some warning that it is not the latest version would be appreciated. I am evaluating this for purchase for a University department, and I have just wasted 2 work days.
To be fair, though, I can say that the support appears excellent!
I share your view regarding not being informed of updated software. I expect this will change soon. Thanks for your comments.
