Compiler: ifx (IFX) 2024.2.0 20240602 (ifx --version)
OS: Rocky Linux 8.9 (Green Obsidian)
I'm not sure how to describe this bug, but here is the code (file attached) that produces the internal compiler error:
! file: minimum_test_to_produce_ice.f90
module EventQueueHeader
implicit none
type Event
end type
class(Event), pointer :: EVENT_NOW => null()
type EventList
contains
generic, public :: get => get_Event
procedure, private :: get_Event
procedure, public :: size => size_EventList
end type
interface
module function get_Event(this,idx) result(object)
class(EventList), intent(inout) :: this
integer, intent(in) :: idx
class(Event), pointer :: object
end function
module function size_EventList(this) result(n)
integer :: n
end function
end interface
type EventQueue
private
type(EventList) :: events
contains
procedure, public :: finalizeCurrentEvent => finalizeCurrentEvent_EventQueue
end type
interface
module subroutine finalizeCurrentEvent_EventQueue(this)
class(EventQueue), intent(inout) :: this
end subroutine
end interface
end module
submodule(EventQueueHeader) EventQueueImplementation
implicit none
contains
integer :: k
do k = 1, this%events%size()
if(associated(this%events%get(k),EVENT_NOW)) then
! do something
return
end if
end do
end subroutine
end submoduleThis ICE occurs if the above code is in a single source file as well as broken apart into two (module and submodule). I compile this on the command line:
ifx -c minimal_test_to_produce_ice.f90Here is the compiler output:
#0 0x0000000003191cf7 (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x3191cf7)
#1 0x000000000317d7d6 (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x317d7d6)
#2 0x000000000309da73 (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x309da73)
#3 0x00000000030a3951 (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x30a3951)
#4 0x0000000003194dfa (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x3194dfa)
#5 0x0000000003198eda (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x3198eda)
#6 0x0000000003169960 (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x3169960)
#7 0x000000000316a5d8 (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x316a5d8)
#8 0x00000000031de4ab (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x31de4ab)
#9 0x00000000031e0db4 (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x31e0db4)
#10 0x00000000031e1335 (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x31e1335)
#11 0x0000000003166477 (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x3166477)
#12 0x0000000003166129 (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x3166129)
#13 0x0000000003167fee (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x3167fee)
#14 0x00000000031e0db4 (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x31e0db4)
#15 0x00000000031e1335 (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x31e1335)
#16 0x00000000031e3d70 (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x31e3d70)
#17 0x00000000031e0db4 (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x31e0db4)
#18 0x00000000031e1335 (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x31e1335)
#19 0x00000000031deb72 (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x31deb72)
#20 0x00000000031e0db4 (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x31e0db4)
#21 0x00000000031de22a (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x31de22a)
#22 0x00000000031e0db4 (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x31e0db4)
#23 0x0000000003078656 (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x3078656)
#24 0x0000000003078005 (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x3078005)
#25 0x000000000324dd27 (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x324dd27)
#26 0x00007f4b84120d85 __libc_start_main (/lib64/libc.so.6+0x3ad85)
#27 0x0000000002eb058a (/opt/intel/oneapi/compiler/2024.2/bin/compiler/xfortcom+0x2eb058a)
minimal_test_to_produce_ice.f90(48): error #5623: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for minimal_test_to_produce_ice.f90 (code 3)
I found a workaround for this bug. I'll only show the relevant portion, and I'll attach the workaround source file.
In the submodule's finalizeCurrentEvent_EventQueue() subroutine, all I had to do was save off the result of the get() function to a local variable:
! ORIGINAL (BUG)
integer :: k
! do something
return
end if
end do
end subroutine
! WORKAROUND
integer :: k
class(Event), pointer :: thisEvent => null()
thisEvent => this%events%get(k)
if(associated(thisEvent,EVENT_NOW)) then
! do something
return
end if
end do
end subroutine
Thank you very much for the ICE report and workaround. I have confirmed and escalated this case to our compiler engineering for a fix.
This issue was fixed in 2025.1 ifx.
