29275 Discussions
Bug Report ICE: "catastrophic error" with ieee_arithmetic module's ieee_value (ifx 2024.2)
jeffhole
Compiler: ifx (IFX) 2024.2.0 20240602 (ifx --version)
OS Rocky Linux 8.9 (Green Obsidian)
I encountered an interesting ICE when setting double precision complex number arrays to "NaN". I don't know if this is a misuse of the ieee_arithmetic's ieee_value(), or if it is standard-compliant, but here it is:
! file: test.f90
program main
    use, intrinsic :: ieee_arithmetic, only: ieee_value, ieee_quiet_nan
    implicit none
    complex(8), allocatable :: x(:)
    allocate(x(3))
    x = cmplx(ieee_value(x%re,ieee_quiet_nan), ieee_value(x%im,ieee_quiet_nan), kind=8)
    print *, x%im
end program
Compiling on the command line:
ifx test.f90
I get this compiler error message:
test.f90(8): internal error: Please visit 'http://www.intel.com/software/products/support' for assistance.
test.f90(8): catastrophic error: Internal Compiler Error: Ref module: ffe_aexpr.c
compilation aborted for test.f90 (code 1)
Workaround
 I found a workaround which is to only pass a single value of x for the first argument of ieee_value():
! file: workaround.f90
program main
    implicit none
    allocate(x(3))
    x = cmplx(ieee_value(x(1)%re,ieee_quiet_nan), ieee_value(x(1)%im,ieee_quiet_nan), kind=8)
    print *, x%im
end program
This seems like the right thing to do. I wanted to share this solution and give the compiler team code to reproduce the error. Thanks!
Labels (2)
Devorah_H_Intel
I reproduced the issue internally. Thank you for the report. This case has been escalated to compiler engineering.
JFH
@jeffhole's test.f90 program compiles and runs correctly with ifort. If one changes the kind 8 to either 4 or 16 it still crashes with ifx and runs correctly with ifort.
Devorah_H_Intel
jeffhole
Thanks @JFH for checking this against ifort. Good thing to know.
You're welcome, @Devorah_H_Intel! Glad to help!
jeffhole
I tested this under the latest release 2025.2.0 and the issue is still showing. I looked at the support ticket opened on my behalf at Intel Support and it's status is "closed: final". Is there a status update on this?
Thank you!
P.S. The support ticket is #06274899, created 2024/07/01 13:09 and last updated 2024/12/19 00:48.
