29657 Discussions
Bug Report: Incorrect application of elemental function on user defined type
Aidan_H_
I have an error with Intel Fortran incorrectly applying an elemental function to a user defined type.
module quart
  implicit none
  type quaternion
     ! q(4) = (w, x, y, z) where w is the scalar part
     real :: q(4)
     ! Flags to tell us if we want to keep the quaternion unitised, and
     ! also if the quaternion represents an improper rotation (rotation + inversion)
     logical :: unit
     logical :: improper
  end type quaternion
contains
  elemental subroutine pnormalise_quaternion(q)
    ! Normalise the quaternion by dividing the quaternion by it's
    ! 'reduced norm'
    type (quaternion), intent(inout) :: q
    q%q = q%q / (pnormq(q))
  end subroutine pnormalise_quaternion
  elemental subroutine enormalise_quaternion(q)
    ! 'reduced norm'
    q%q = q%q / (enormq(q))
  end subroutine enormalise_quaternion
  pure real function pnormq(q)
    ! The 'reduced norm' of a quaternion is just the square root of the
    ! arithmetic sum of the squares of it's elements
    real :: normq
    type (quaternion), intent(in) :: q
    pnormq = sqrt(sum(q%q**2))
  end function pnormq
  elemental real function enormq(q)
    real :: normq
    enormq = sqrt(sum(q%q**2))
  end function enormq
end module quart
program test
    use quart
    type(quaternion) :: q(2)
    q(1)%q = [1,2,2,4]
    q(2)%q = [1,0,0,0]
    call pnormalise_quaternion(q)
    write(*,*) q(1)%q
    write(*,*) q(2)%q
    q(1)%q = [1,2,2,4]
    q(2)%q = [1,0,0,0]
    call enormalise_quaternion(q)
    write(*,*) q(1)%q
    write(*,*) q(2)%q
end program
Compiled and run like so:
fort -o quaternion quaternion.f90​
./quaternion
  0.2000000      0.4000000      0.4000000      0.8000000
 1.000000      0.0000000E+00  0.0000000E+00  0.0000000E+00
  0.2000000      0.4079085      0.4449238      0.9875987
The top two lines are correct (from the pure routine), and the third line is erroneous.
Stepping through the code with gdb it seems that enormq is being 4 times for each quaternion q, once for each element of q%q.
Aidan_H_
I meant to add, the same result was obtained with the following compilers
ifort -V
Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 13.1.2.183 Build 20130514
Copyright (C) 1985-2013 Intel Corporation.  All rights reserved.
and
ifort -V
Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.0.090 Build 20140723
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
but correct results were obtained with gfortran 5.2.0
FortranFan
The latest version of Intel Fortran compiler - 16, update 1 - seems to give results as expected.
Aidan_H_
Great. Thanks for the feedback.
