29311 Discussions
Bug: ifx does not assign back the real/imaginary part of the component of a structure
WiserOrb
In the program i pass the real part of a component of a structure to the subroutine foo that set a value
However the matrix A is not changed by the procedure call
If I pass a matrix that is NOT a component, it correctly modifies it
main.f90
program main
    type :: Bar
        complex(kind=8) :: A(2)
    end type
    type(Bar) :: x
    x%A%re = 1.0_8
    x%A%im = 2.0_8
    call foo(3.0_8, x%A%re)
    write (*,*) x%A
    contains
    subroutine foo(v, A)
    real(kind=8) :: v, A(:)
    integer(kind=4) :: i
    A = v
    write(*,*) A
  end subroutine
end program
Output of ifx version 2025.1.1
3.00000000000000        3.00000000000000
 (1.00000000000000,2.00000000000000) (1.00000000000000,2.00000000000000)
The output should be:
 (3.00000000000000,2.00000000000000) (3.00000000000000,2.00000000000000)
Xiaoping_D_Intel
I can reproduce the error and will open a bug report for it.
