29375 Discussions
Bug in IFX - Standalone BLOCK DATA Source File in Library
Stuart-McDonald
I'm seeing what I think may be a bug in the IFX compiler. I have a common block variable initialized in BLOCK DATA file in a standalone source file and a subroutine that are compiled into a library. The subroutine has a reference to "EXTERNAL <blockDataName>" to ensure that the BLOCK DATA file is compiled in. The library is then compiled into a program and the program writes out the value of the variable. In IFX, built into a Library, the value is 0 (not initialized to the BLOCK DATA value). In IFX compiled all at once, or in IFORT either way, the value is correct.
The issue can be reproduced with the following files:
testsub.f:
      subroutine testSub
	      INCLUDE 'bd.fi'
	      EXTERNAL BDINIT
		  WRITE(*,*) "myvar is",myvar
	  end subroutine
bd.fi:
      double precision myvar
      common/mycommon/myvar
bdinit.f:
      BLOCK DATA BDINIT
      INCLUDE 'BD.FI'
      DATA myvar / 3.14159 /
      END
main.f:
      program testProgram
          call testSub
      end program
build.bat:
ifx /Qsave /Qinit:zero /libs:static /c testsub.f bdinit.f
lib /out:IfxLib.lib testsub.obj bdinit.obj
ifx main.f IfxLib.lib /o IfxWithLib.exe
ifx main.f testsub.f bdinit.f /o IfxNoLib.exe
del *.obj
ifort /Qsave /Qinit:zero /libs:static /c testsub.f bdinit.f
lib /out:IfortLib.lib testsub.obj bdinit.obj
ifort main.f IfortLib.lib /o IfortWithLib.exe
ifort main.f testsub.f bdinit.f /o IfortNoLib.exe
del *.obj
IfxWithLib.exe
IfxNoLib.exe
IfortWithLib.exe
IfortNoLib.exe
 Result (Intel Fortran Compiler 2024.0.0):
I:\Temp\Limerick\ifx_blockdata>IfxWithLib.exe
 myvar is  0.000000000000000E+000
I:\Temp\Limerick\ifx_blockdata>IfxNoLib.exe
 myvar is   3.14159011840820
I:\Temp\Limerick\ifx_blockdata>IfortWithLib.exe
I:\Temp\Limerick\ifx_blockdata>IfortNoLib.exe
Arjen_Markus
I do not know what is or is not required by the standard vis-à-vis BLOCK DATA, but in the past I had to explicitly link in the BLOCK DATA object file because it would not work via a library. But I have never used the EXTERNAL statement to force a reference like that. I can imagine that this is a rather grey area in the standard.
mecej4
Here is a slightly different way of establishing that IFX is not alert enough. Take the single file Tsub1.f containing
      subroutine testSub
      EXTERNAL BDINIT
      end subroutine
and compile with (a) Ifort and (b) Ifx, without attempting to link anything, and examine whether the resulting OBJ file contains the unsatisfied external BDINIT.
S:\LANG\smd>ifort.exe /c tsub1.f & dumpbin /symbols tsub1.obj | findstr /i bdinit
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.11.0 Build 20231010_000000
Copyright (C) 1985-2023 Intel Corporation.  All rights reserved.
00F 00000000 UNDEF  notype ()    External     | BDINIT
S:\LANG\smd>ifx.exe /c tsub1.f & dumpbin /symbols tsub1.obj | findstr /i bdinit
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2024.0.0 Build 20231017
S:\LANG\smd>
IFX probably sees that there is a declaration for BDINIT but no reference to it, and there is nothing in the code to tell IFX that BDINIT is a code symbol and not a data symbol. In situations such as this, I feel handicapped by not having a way of declaring, "BDINIT is a typeless procedure, i.e., one that returns no value, i.e., a subroutine", or, alternatively, "BDINIT is not a data section/segment item".
Barbara_P_Intel
Thank you for reporting this. I think I see what you see on Windows, but not on Linux. Interesting that Linux cares about the case in the INCLUDE statement file name, but Windows does not.
I'll get a bug filed.
Steve_Lionel
I'll comment that an EXTERNAL declaration, without a reference, is exactly the way a BLOCK DATA is supposed to be pulled in from a library. It does not astonish me that this detail was missed in IFX, but it does need to work.
Barbara_P_Intel
I filed CMPLRLLVM-55045 to get this fixed.
NasarAli
I am facing the same issue. Is it fixed or not?
Barbara_P_Intel
The fix is in progress. I don't have a due date.
Lukasz_H_1
I can only tell that I am also experiencing issue with this bug, i.e. when building with IFX rather than IFORT with hexacty the same project structure  (Common block etc.).
Please note that I have the latest Intel Fortran compiler installed (2024.2.1)  and this issue is still present.
With IFORT being planned for a withdrawal near end of 2024 it would be good to know when this is going to be fixed, unless there is some clear advice with a workaround.
By the way, the "Release Notes" for Fortran 2024.2.1:
Intel® Fortran Compiler for oneAPI Release Notes
point to Release Notes that say "2024.2.0" and the date mentioned is 13 June rather than 05 August (as seen in the individual components page for Intel Fortran compiler)
Lukasz
Devorah_H_Intel
There were no changes to the IFX compiler between 2024.2.0 and 2024.2.1 oneAPI Toolkits releases - hence, the Release Notes remained unchanged.
The compiler development team is working on the fix. I will update you when it will be available.
Hiram_Brown
Is this bug still in work.  I see that it was reported a year ago.  I observed the same issue with my legacy applications.
Hiram_Brown
My latest download of ONEAPI did not include IFORT so I am dependent on IFX.  I have a very unpopular work around that involves pulling all BLOCK DATA code from the static library code to a single file so that it can be manually compiled into the application that requires the static library.  I would request that this issue be addressed so that legacy applications can be built properly.
Devorah_H_Intel
There is no fix.
Please check the Release Notes https://www.intel.com/content/www/us/en/developer/articles/release-notes/oneapi-fortran-compiler-release-notes.html
Particularly this part under Known Issues:
BLOCK DATA
  • On Windows systems, a subprogram built into a library that references a common block variable initialized in a BLOCK DATA subprogram that is compiled separately and linked with the library will not get initialized but will have a zero value.  The workaround for this problem is to compile the subprogram and the BLOCK DATA subprogram together, or pass the object file with BLOCK DATA separately on the link line.
