29652 Discussions
Issue with allocatable strings and O1, O2 and O3 (IFX)
Olsen__Oystein
I have an issue with the IFX- compiler. The attached program works with -O0, but not -O1, -O2 and -O3. (It works with ifort, gfortran and nagfor).
Commands to compile with -O1, and to run the test program:
make O1
./bug_string
Use corresponding commands for -O0, -O2 and -O3. The expected output is:
 # --epoch#
 # --epoch#
With -O1 I get:
The weird thing is that I get the expected results if I uncomment line 65 in the code. That line only writes a few character to stdout, and should have no effect at all.
Olsen__Oystein
As with my other issue, this too works when adding --noauto as an option to the compiler, and works with ifort 2021.8.0.
Øystein
Devorah_H_Intel
I was able to reproduce the issue reported here. This case is now escalated to compiler engineering.
Devorah_H_Intel
The fix for this bug has been implemented in the 2025.2 version of ifx.
