29487 Discussions
Bug in Intel 2019 with private attribute
lina
module Timer_c
  implicit none
  private
  type, public :: timer_t
    private
    real :: savedTime
  contains
    private
    procedure :: StartTimer  => StartTimerSub
    procedure :: ElapsedTime => ElapsedTimeFun
  end type timer_t
contains
  subroutine StartTimerSub(this)
    class(timer_t) :: this
    this%savedTime = 0.0
  end subroutine StartTimerSub
  function ElapsedTimeFun(this) result(retVal)
    real :: retVal
    retVal = 1.0 - this%savedTime
  end function ElapsedTimeFun
end module Timer_c
program TestTimer
  use Timer_c
  implicit none
  type(timer_t) :: t
  call t%StartTimer()
  write(*, *) t%ElapsedTime()
end program TestTimer
Both StartTimer and ElapsedTime are declared as private, but the compiler give only one error that ElapsedTime is private, StartTimer is still accessible in main program. That means functions are handled correctly, not subroutines. However, in gfortran compilers, both errors are detected. I think this is a bug.
