29487 Discussions
Bug in Intel 2019u1 with INQUIRE and WRITE
Jacob_Williams
New Contributor III
I'm seeing a bug in Intel 2019u1 (after updating from 2017u4). The following is a very stripped-down example that shows the problem:
program main
  implicit none
  integer :: file_id,iostatus
  logical :: status_flag
  character(len=:),allocatable :: str
  file_id = 1003
  open(unit=file_id,file='test.txt',status='REPLACE',iostat=iostatus)
  str = '1'
  inquire(unit=file_id, opened=status_flag, iostat=iostatus)
  write(file_id,fmt='(A)',advance='NO',iostat=iostatus) str
  str = '2'
  str = '3'
  close(unit=file_id)
end program main
The contents of the resulting file should be "123", but I'm getting only "3". If I comment out the INQUIRE calls, it works as expected. It seems like the INQUIREs are interfering with or preventing some of the WRITE statements in some way.
I'm using the 64 bit compiler on Windows 10. Same results for both Debug and Release builds.
Johannes_Rieke
New Contributor III
Hi Jacob, I can confirm that behavior for PSXE2018u3 and PSXE2019u1. PSXE2017u6 works as expected with inquire present. Gfortran 8.2.1 delivers also '123'. It would be good to open a ticket at OSC to get the Intel team informed.
BR, Johannes
Jacob_Williams
New Contributor III
Done (Support request number 03934032)
