29293 Discussions
Bug in Intel LLVM fortran compiler?
Rubo
Compiling a regular modern Fortran code I got this error. I am wondering if I hit a bug in the compiler:
LLVM ERROR: Cannot select: 0x8aed4b0: i32 = zero_extend 0x88482e0, /programming/SIMPLE/src/utils/simple_linalg.f90:838:41
0x88482e0: v8i1 = xor 0xafffe70, 0xc261290, /programming/SIMPLE/src/utils/simple_linalg.f90:778:9
0xafffe70: v8i1 = or 0xd8e4270, 0x7d944a0, /programming/SIMPLE/src/utils/simple_linalg.f90:778:9
0xd8e4270: v8i1 = insert_subvector 0xc261680, 0x9cdd490, Constant:i64<0>, /programming/SIMPLE/src/utils/simple_linalg.f90:778:9
0xc261680: v8i1 = BUILD_VECTOR Constant:i8<0>, Constant:i8<0>, Constant:i8<0>, Constant:i8<0>, Constant:i8<0>, Constant:i8<0>, Constant:i8<0>, Constant:i8<0>, /programming/SIMPLE/src/utils/simple_linalg.f90:778:9
0x8848190: i8 = Constant<0>
0x9cdd490: v4i1 = setcc 0x7852180, 0xa258910, setugt:ch, .....
Ron_Green
there is not enough information here for us to comment or help.
First, what version of IFX?
What OS?
What application, compiler options, etc.
Ideally we could use a .zip or .tgz of the application or a pointer to it's github location.
Rubo
IFX version ifx (IFX) 2024.0.2 20231213
Linux OEL8 Red Hat Enterprise Linux release 8.9 (Ootpa)
Application: https://github.com/hael/SIMPLE
Compilation script: https://github.com/hael/SIMPLE/compile_intel.sh
Thanks!!!
Ron_Green
I cannot get far enough into the build to see what you are seeing.  Is there a branch you are using?
I also changed the CXX compiler to 'icpx' instead of icx-cc
First I hit
[  4%] Building Fortran object lib/CMakeFiles/SIMPLE3.0.0.dir/utils/simple_rnd.f90.o
/nfs/site/home/rwgreen/projects/simple/SIMPLE/src/utils/simple_rnd.f90(36): error #6405: The same named entity from different modules and/or program units cannot be referenced.   [LONG]
integer(long), save :: idum
/nfs/site/home/rwgreen/projects/simple/SIMPLE/src/utils/simple_rnd.f90(36): error #6683: A kind type parameter must be a compile-time constant.
which looks like it could be a bug reported already.
So I replaced 'long' with '
selected_int_kind(9)'
which you had as it's kind in defs.  that got me past simple_rnd.f90.  Then I hit a slew of errors
[  4%] Building Fortran object lib/CMakeFiles/SIMPLE3.0.0.dir/main/simple_ori.f90.o
/tmp/ifx0104453423caFwu4/ifxRXHpL1.i90: error #8262: For a type-bound procedure that has the PASS binding attribute, the first dummy argument must have the same declared type as the type being defined.   [PID]
/nfs/site/home/rwgreen/projects/simple/SIMPLE/src/main/simple_ori.f90(1482): error #6645: The name of the module procedure conflicts with a name in the encompassing scoping unit.   [KILL]
    subroutine kill( self )
/nfs/site/home/rwgreen/projects/simple/SIMPLE/src/main/simple_ori.f90(153): error #6552: The CALL statement is invoking a function subprogram as a subroutine.   [KILL]
        call self%kill
/nfs/site/home/rwgreen/projects/simple/SIMPLE/src/main/simple_ori.f90(153): error #6074: The number of actual arguments does not match the definition.   [KILL]
        call self%kill
/nfs/site/home/rwgreen/projects/simple/SIMPLE/src/main/simple_ori.f90(153): error #6631: A non-optional actual argument must be present when invoking a procedure with an explicit interface.   [PID]
        call self%kill
/nfs/site/home/rwgreen/projects/simple/SIMPLE/src/main/simple_ori.f90(153): error #6631: A non-optional actual argument must be present when invoking a procedure with an explicit interface.   [SIGNUM]
        call self%kill
/nfs/site/home/rwgreen/projects/simple/SIMPLE/src/main/simple_ori.f90(1841): error #6552: The CALL statement is invoking a function subprogram as a subroutine.   [KILL]
        call e1%kill
/nfs/site/home/rwgreen/projects/simple/SIMPLE/src/main/simple_ori.f90(1841): error #6074: The number of actual arguments does not match the definition.   [KILL]
        call e1%kill
/nfs/site/home/rwgreen/projects/simple/SIMPLE/src/main/simple_ori.f90(1841): error #6631: A non-optional actual argument must be present when invoking a procedure with an explicit interface.   [PID]
        call e1%kill
/nfs/site/home/rwgreen/projects/simple/SIMPLE/src/main/simple_ori.f90(1841): error #6631: A non-optional actual argument must be present when invoking a procedure with an explicit interface.   [SIGNUM]
        call e1%kill
/nfs/site/home/rwgreen/projects/simple/SIMPLE/src/main/simple_ori.f90(1842): error #6552: The CALL statement is invoking a function subprogram as a subroutine.   [KILL]
        call e2%kill
/nfs/site/home/rwgreen/projects/simple/SIMPLE/src/main/simple_ori.f90(1842): error #6074: The number of actual arguments does not match the definition.   [KILL]
        call e2%kill
/nfs/site/home/rwgreen/projects/simple/SIMPLE/src/main/simple_ori.f90(1842): error #6631: A non-optional actual argument must be present when invoking a procedure with an explicit interface.   [PID]
        call e2%kill
/nfs/site/home/rwgreen/projects/simple/SIMPLE/src/main/simple_ori.f90(1842): error #6631: A non-optional actual argument must be present when invoking a procedure with an explicit interface.   [SIGNUM]
        call e2%kill
/nfs/site/home/rwgreen/projects/simple/SIMPLE/src/main/simple_ori.f90(1843): error #6552: The CALL statement is invoking a function subprogram as a subroutine.   [KILL]
        call e3%kill
/nfs/site/home/rwgreen/projects/simple/SIMPLE/src/main/simple_ori.f90(1843): error #6074: The number of actual arguments does not match the definition.   [KILL]
        call e3%kill
/nfs/site/home/rwgreen/projects/simple/SIMPLE/src/main/simple_ori.f90(1843): error #6631: A non-optional actual argument must be present when invoking a procedure with an explicit interface.   [PID]
        call e3%kill
/nfs/site/home/rwgreen/projects/simple/SIMPLE/src/main/simple_ori.f90(1843): error #6631: A non-optional actual argument must be present when invoking a procedure with an explicit interface.   [SIGNUM]
        call e3%kill
compilation aborted for /nfs/site/home/rwgreen/projects/simple/SIMPLE/src/main/simple_ori.f90 (code 1)
Rubo
I am using the master branch. This is really interesting,, which is the version of IFX that you are using?
Rubo
Ron, I was able to reproduce your error with IFX versions 2023.1.0 and 2023.2.0.
Using IFX 2024.1.0 I got the errors reported initially in my post.
