29256 Discussions
Bug in Linux X64 versions of IFort 11.1, 12.0
mecej4
This bug report has its origins in a post by Alfredo Buttari "passing float _Complex from C to Fortran" with a C main calling a Fortran subroutine and passing a complex argument by value. Here is a program, entirely in Fortran, that reproduces the bug.
[fortran]program xplx
complex :: x
x=cmplx(0.0,1.0)
write(*,*)' Before call, x = ',x
call func(x)
contains
subroutine func(x)
complex, value :: x
write(*,*)' Inside subr, x = ',x
return
end subroutine func
end program xplx
[/fortran] The result from the 32-bit compiler:
[bash] $ ./a.out
Before call, x = (0.0000000E+00,1.000000)
Inside subr, x = (0.0000000E+00,1.000000)
[/bash] and, from the 64-bit compiler:
[bash]$ ./a.out
Inside subr, x = (0.0000000E+00,0.0000000E+00)
[/bash]
There is a mismatch in the argument passing scheme at the assembler/machine level in x64 mode. The caller passes the real and imaginary parts of the single argument in the two halves of xmm0, loading xmm0 from the stack with one movsd. The subroutine expects the two parts in xmm0 and xmm1, which it moves onto the subroutine's stack with two movss instructions. At this point, however, xmm1 contains junk.
The bug is not seen when the argument is passed by reference.
Kevin_D_Intel
We really appreciate the extra effort to provide this reproducer, mecej4. I reported this defectto Development (internal tracking id noted below) and will keep both posts updated with new status as I learn it.
(Internal tracking id: DPD200198349) (Resolution Update on 10/14/2012): This defect is fixed in the Intel® Fortran Compiler XE Update 6 (12.1.0.233 - Linux)
Kevin_D_Intel
My apologies for the delayed update. This defect is fixed in the Intel® Fortran Compiler XE Update 6 (12.1.0.233 - Linux)
