29342 Discussions
Bug regarding warnings about line truncation
Weser__Oskar
I am working on a fixed format Fortran legacy program and found a bug regarding the warnings about line truncation.
If you compile the following program using:
ifort  -warn all,error source_truncation.f
      program source_truncation
      integer :: i
* This comment exceed column 72 and does not lead to an error.  pewpepepwwepwepwe
      ! This comment exceeds column 72 and does lead to an error.  pewpepepwwepwe
      i = 1 + 2
      write(*, *) i
      end program
you will get an error only for the second comment.
It is a bit inconsistent, that a comment, as defined by a character in the first column, and a comment, as defined by exclamation marks, are treated differently.
The tested compilers are:
ifort (IFORT) 18.0.1 20171018
ifort (IFORT) 16.0.1 20151021
