Bug report for ICE in ifx
krefson
The following program
program myfunc
    use omp_lib
end program myfunc
 generates an ICE when the attempt is made to compile using
ifx -fsyntax-only test_omp_lib.f90
ifx test_omp_lib.f90: error #5633: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line
given may not be explicit cause of this error
This is with ifx (IFORT) 2022.0.0 20211123, although it seems to happen with all versions
KR
Ron_Green
I see the error in all IFX compilers in the 2022.x versions.  However, I just tested with the upcoming 2023.0.0 compiler and it's fixed.  As Barbara said, we are SOOOO close to releasing this v2023.0.0 compiler!
Watch for our announcement really soon on it's release.
ron
Ron_Green
ron
