- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Our program is a combination of C++ and Fortran. Recently, we upgraded the Fortran compiler to ifx2024 or ifx2025. We encountered an issue that seems to be related to the Fortran Preprocessor (fpp) starting from oneAPI2024, which was not present in oneAPI2023 and earlier versions.
Bug Description and Steps to Reproduce:
We have simplified the steps to reproduce the bug. Create two files, Defines.h and main.f, with the following content:
Defines.h
#define some_var 1
#ifdef __cplusplus
#ifdef another_condition
#ifdef _WIN32
#define var_cpp_1 1
typedef _int64 GlobalID;
#endif
#endif /* another_condition */
#endif /* __cplusplus */main.f
PROGRAM MAIN
#include "Defines.h"
PRINT *, some_var
ENDThen, execute the command:
ifx -fpp main.f -o main
This issue occurs with both ifx and ifort in oneAPI2024, as well as with ifx in oneAPI2025.
Based on my observations, the bug appears under the following conditions:
- There is a nested #ifdef closure (at least three levels)
- C++ syntax code is present within the 3-level nested section.
Could Intel experts please provide assistance with this issue? Any fixes or workarounds would be greatly appreciated. Thank you for your help!
Shuhui
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
The documentation says (and has always said), "All fpp preprocessor directives start with the number sign (#) as the first character on a line. White space (blank or tab characters) can appear after the initial # for indentation."
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Can someone please take a look and verify if it is a bug?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Intel fpp requires the "#" to be in column 1
Jim Dempsey
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Thank you, Jim. I guess it is a new requirement introduced in oneapi2024.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
