- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I have found another possible bug in ifx.
Steps to reproduce:
Put the following in simdfunctions_mod.F90:
MODULE simdfunctions_mod
IMPLICIT NONE (type, external)
PRIVATE
PUBLIC :: divide0
CONTAINS
PURE ELEMENTAL REAL FUNCTION divide0(a, b) RESULT(res)
!$omp declare simd(divide0)
REAL, INTENT(in) :: a, b
IF (b == 0.0) THEN
res = 0.0
ELSE
res = a/b
END IF
END FUNCTION divide0
END MODULE simdfunctions_modAnd put the following in efvisc.F90:
MODULE efvisc_mod
USE simdfunctions_mod
PRIVATE
PUBLIC :: efvisc
CONTAINS
SUBROUTINE efvisc(kk, jj, ii, bu, graduz)
! Subroutine arguments
INTEGER, INTENT(in) :: kk, jj, ii
REAL, INTENT(in) :: bu(kk, jj, ii)
REAL, INTENT(in) :: graduz(kk, jj, ii)
! Local variables
INTEGER :: k, j, i
REAL :: dudz(kk-4)
REAL :: dd1, dd2, dd3, dd4, ddd
DO i = 3, ii-2
DO j = 3, jj-2
!$omp simd private(dd1, dd2, dd3, dd4, ddd)
DO k = 3, kk-2
! dU/dZ
dd1 = bu(k+1, j, i)*bu(k, j, i)
dd2 = bu(k, j, i)*bu(k-1, j, i)
dd3 = bu(k+1, j, i-1)*bu(k, j, i-1)
dd4 = bu(k, j, i-1)*bu(k-1, j, i-1)
ddd = dd1 + dd2 + dd3 + dd4
dudz(k-2) = divide0(graduz(k, j, i)*dd1 &
+ graduz(k-1, j, i)*dd2 &
+ graduz(k, j, i-1)*dd3 &
+ graduz(k-1, j, i-1)*dd4, ddd)
END DO
IF (i == 18 .AND. j == 18) THEN
k = 33
WRITE(*, *) "dudz = ", dudz(k-2)
END IF
END DO
END DO
END SUBROUTINE efvisc
END MODULE efvisc_mod
PROGRAM main
USE efvisc_mod
INTEGER, PARAMETER :: ii = 36, jj = 36, kk = 36
REAL :: bu(kk, jj, ii)
REAL :: graduz(kk, jj, ii)
! Initialize the RNG to give the same (compiler-dependent) random
! sequence every time
CALL RANDOM_INIT(.TRUE., .FALSE.)
! Initialize variables
bu = 1.0
CALL RANDOM_NUMBER(graduz)
CALL efvisc(kk, jj, ii, bu, graduz)
END PROGRAM mainIt is essential that these two pieces of code go in different files, otherwise the bug won't show up. Now compile with ifx, using -O0 optimization level. The output of this is the reference (which is assumed to be correct):
$ ifx -O0 simdfunctions_mod.F90 efvisc2.F90 && ./a.out
dudz = 0.4440139Compile over again with -O1 or higher and the result changes completely. This is wrong:
$ ifx -O1 simdfunctions_mod.F90 efvisc2.F90 && ./a.out
dudz = 0.5154935Please note that the graduz array is filled with random numbers, and the results on your computer/architecture might differ. The key point is that it should produce the same result with both -O0 and -O1 (and other optimization levels).
Analysis:
The critical source file is efvisc.F90, when this is compiled with -O0 everything works and when this is compiled with -O1 or higher it does not work. If you compile simdfunctions_mod.F90 separately with for instance -O3 it will still works as long as efvisc.F90 is compiled with -O0.
Compiling efvisc.F90 with -qno-openmp-simd will also solve the problem and produce the correct result with all optimization levels (independent on how simdfunctions_mod.F90 is compiled).
ifort produce the expected output in all cases (ifort does not enable openmp-simd until -O2, this differ from ifx that enable it at -O1):
$ ifort -O3 -diag-disable=10448 simdfunctions_mod.F90 efvisc2.F90 && ./a.out
dudz = 0.4440139Since the program rely on a random (but seeded in a predictable way) generated field, the results with different compilers will vary, but trying with gfortran I cannot find any errors in the results and my program execute just fine, the results are the same independent on openmp-simd and optimization level.
Workaround:
Change the efvisc-subroutine to:
! Local variables
INTEGER :: k, j, i
REAL :: dudz(kk-4)
REAL :: dd1, dd2, dd3, dd4, dsum, ddd
DO i = 3, ii-2
DO j = 3, jj-2
!$omp simd private(dd1, dd2, dd3, dd4, dsum, ddd)
DO k = 3, kk-2
! dU/dZ
dsum = graduz(k, j, i)*dd1 &
dudz(k-2) = divide0(dsum, ddd)
END DO
k = 33
END IF
END DO
END DO
END SUBROUTINE efviscThe difference is that the new variable dsum (which is also declared private in the simd construct) contains the expression that was previously in the function call to divide0. This seems to solve the problem.
ifx version:
$ ifx --version
ifx (IFX) 2024.1.0 20240308
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.Final remark:
I'm always careful to conclude that something is a compiler bug, the Fortran programming language and associated OpenMP specification has way too many caveats and pitfalls for me to know them all. But the behavior here seems fishy and I cannot see any obvious mistakes in my code.
I really appreciate all comments, feedback and help!
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Thank you for the nice triage of this issue! Usually when there's a runtime failure at -O1 and above, but works ok at -O0 it's an issue with the compiler.
I filed a bug report, CMPLRLLVM-57890. We'll let you know when it's fixed.
