Bug with STORAGE_SIZE?
Jacob_Williams
New Contributor III
I'm seeing something odd here. If I use STORAGE_SIZE on a CLASS(*) variable to initialize a character string using REPEAT, the result is different if I put the size in a temporary variable, or in the actual routine call.  See below:
program test
  implicit none
  call bug(1)
contains
  subroutine bug(k)
   use iso_fortran_env, only: CHARACTER_STORAGE_SIZE
   implicit none
   class(*),intent(in) :: k
   character(len=:),allocatable :: s1,s2
   integer :: n
   n = storage_size(k)/CHARACTER_STORAGE_SIZE	!works if size is put in temp variable
   s1 = repeat(' ', n)
   write(*,*) 'len(s1)=',len(s1)	!prints 4
   s2 = repeat(' ', storage_size(k)/CHARACTER_STORAGE_SIZE)	!doesn't work!
   write(*,*) 'len(s2)=',len(s2)	!prints 0
  end subroutine bug
end program test
Kevin_D_Intel
Thank you for reporting this and for the nice reproducer. It does appear the usage producing the incorrect results should work. I reported this to Development.
(Internal tracking id: DPD200378821)
