29281 Discussions
Bug with ifort >= 12 + OpenMP + O>=2 + pointer + matrix storage.
Olivier_C_
I think I met a bug with Intel Ifort 12 or more, when + compiling with -openmp a subroutine + with a parallel region (not met at runtime but taken into acount by the compiler) + at optimization level O2 or more. The very simple code reproducer consists in: - allocate a structure array that is a two dimensional array, - allocate a temporary pointer array in a routine, copy the strycture array into it, then copy the temporary array back to the structure array. When the back copy is the fortran 90 style ( struct%tab(:) = tmparray(:)) it is OK, when it is a manual loop, we get a forrtl: severe (174): SIGSEGV, segmentation fault occurred It is fine when structure array is one dimensional, or when the temporary array is ALLOCATABLE, or when there is a print inside the manuel loop (no vectorization). To compile and test: ifort -openmp -O3 main.f90 myfcell.f90 && ./a.out
Ron_Green
We will investigate.  Thank you for the test case.
ron
Ron_Green
I opened a bug report on this.  It seems to affect versions 12.0, 12.1, and 13.  It is not present in version 11.x compilers.
We will let you know when a fixed compiler is available.
Olivier_C_
Fixed by Version 13.1.1.163 Build 20130313.
