Build fails for no apparent reason
WSinc
When I just added a new routine PAWN, it tells me that there are TWO MAIN programs.
When I remove that routine, it builds with no problems, providing I remove the CALL to it.
All routines in the project compiled with no errors or warnings
The PAWN routine has the exact same interface as 5others, so I don't see
why it would trigger this error message. I don't see anyhting unusual about it, in other words.
I am wondering if "stripping the guts out" wouldallow itto complete the build.
I will experiment further.
The enclosed archive was made with 7-ZIP, its supposed to be compatible.
Could this be an environmental concern? I tunred off the SPYWARE, and did a reboot, same result.
Any ideas?
IanH
Right at the bottom of pawn.f90 (line 47, ten lines below the rest of the code) you have a stray END statement. An end statement on its own is valid - it defines a empty main program. That empty main program clashes with your other "intended" main program.
IanH
WSinc
Boy, I never would have caught that ! ! !
But why wouldn't it look for a PROGRAM statement?
It seems rather strange, anyway - - - -
PROGRAM statement is optional - as Ian says, an END not preceded by a SUBROUTINE, FUNCTION, BLOCK DATA or MODULE, ends a main program.
