Note for those doing a "Rebuild All' and/or'Clean Solution'.
After scratching my head for a while wondering 'why am i getting these strange errors' when I used 'rebuild all' after executing a 'clean solution' command, I found that many files are not 'cleaned' out from the Debug and/or Release diectories.
And those remaining files may produce strange errors.
The project had been recomiling fine with interim recompilations and I wanted to cleanup everything and ran into the problem.
I suggest totruly 'clean' your Debug and/or Release directory before a Rebuild all command is executed I would recommend going to the debug and/or Release directories and deleting all files manually before the Rebuild all command.
Apparently when you rename/redefine/etc files while doing interim recompiles, it somehow ignores the old/unused files? and doesn't clean them out so when you try Clean Solution and then rebuild ALL, some of the old files may conflict with the new/clean rebuild.
Just a note. Don't know if this is the expected behavior.
I am using the latest (74, recently updated in last day) 11.0.3454.2003 with .NET 2003
Quoting - bmchenry
Yes, this is the expected behavior.
I understand your frustration, but in my opinion it's much better this way, i.e. the IDE should only handle the items it knows about, for a couple of reasons:
* You may reconfigure your solutions so that the intermediate and output files go to a quite diverse family of directories, rather than just "Debug" or "Release" subdirectorise. You can't wipe out everything in sight.
* As a corrolary, user may keep its input or auxiliary files in those Debug or Release directories. You don't want them silently destroyed.
I agree Jugoslav,
Don't want rebel robotics deleting stuff it knows nothing about!
I found the reason for my initial problems eith build 74 which i attributed to the'unclean' directory were really build interface block issues.
That now being solved the need to clean out the directory manually is not longer required.
Thanks!
brian
Thanks!
brian
There is also the option "Extensions to Delete on Clean" (Project>Properties>General; MS Visual Studio 2005)to add deletion of file patterns that can crop of regularly, such as interfaces.
