C Fortran communication
patuco
Hi everyone,
i have a problem with the c fortran communication: I am trying to send an string to fortran form a C library, but the fortran code is becoming some unreadle characters, I tryed a couple ideas and suggestions but i do not know what i am missing, Anyone could give me a hand?
Thanks in advance.
What i have implemented is:
---------------------------- C call ----------------------------
extern "C" void __stdcall Setmolbyname(char *, int);
---------------------------- Cfunc ----------------------------
JNIEXPORT void JNICALL Java_Main_set_1molecule_1name(JNIEnv *env, jobject jobj, jstring prompt)
int size = 20;//TEST ONLY --> DEFINE A CONSTANT WITH THE VALUE OF THE MINIMUM LENGTH OF THE STRING
char * buf ;
printf("Calling the c function ");
buf = (char *)calloc(size,sizeof (char));
buf = (char *)env->GetStringUTFChars(prompt,NULL);
printf("String c1: %s ", buf);
printf(" Calling fortran with the chain %s ", buf);
fflush(stdout);
Setmolbyname(buf, size);
//printf("Release the jstring: %s ", buf);
env->ReleaseStringUTFChars(prompt, buf);
//printf("Ending C ");
---------------------------- endCfunc ----------------------------
---------------------------- fortran func ----------------------------
SUBROUTINE SETMOLBYNAME(NEWMOLEC, i_Len)
!MS$ATTRIBUTES DLLEXPORT,STDCALL,ALIAS:'_Setmolbyname@8'::SETMOLBYNAME
INCLUDE 'COM_MASE.LVG'
CHARACTER*20 NEWMOLEC
INTEGER i_Len
WRITE(*,*) "Molec in fortran "
WRITE(*,*) NEWMOLEC
DCOM ='MOLE'
RDCOM=NEWMOLEC
END SUBROUTINE
---------------------------- end fortran func ----------------------------
---------------------------- output ----------------------------
String c1: SIO
Calling fortran with the chain SIO
Molec in fortran
Molec in fortran
---------------------------- end output ----------------------------
TimP
As the Fortran CHARACTER argument implies a hidden length argument which is seen only on the C side, it looks like you have an extra argument on the Fortran side. AFAIK stdcall is not recommended, as it is not supported on 64-bit Windows, for example. Also, Fortran CHARACTER argument is a compiler-dependent extension, not strictly permitted by stdcall.
You would normally use strlen(), for example, to pass the actual length of the string, and use that length on the Fortran side. It looks here like you are trying to display the trailing null and subsequent uninitialized characters on the Fortran side.
I/O to the same stream by both C and Fortran, without precautions, is problematic. Maybe you could do it with a flush on the Fortran side as well.
Check the examples which come with your choice of Fortran and adhere more closely to them.
patuco
Many thanks for the reply Tim,
Ive already tryed with this other config (using the implicit arguments) but getting the same answer, an unreadable chain.
It seems like fortran is not becoming the chars from c !!!!???:
SUBROUTINE SETMOLBYNAME(NEWMOLEC)
about the length it can be done easily but for the moment i am trying to make this part work, and i do not know how to solve this stage. Thanks
Message Edited by patuco on 03-29-200601:54 AM
