L
StringBuilder cname =
new StringBuilder(32);cname.Append(' ',cname.Capacity);
CsDllIntWrap.CSDLLCNAME( cname, cname.Length );
int isymcur=99;int isymtmp=0;int ndim=0;int ierr=0; int[,] isize = new int[2,2];StringBuilder cerr =
new StringBuilder(1024);cerr.Append(' ',cerr.Capacity);
int[] iary = {1,2,3,4};ra1_forptr ia =
new ra1_forptr();ia.baseaddr=0;
CsDllIntWrap.FORPTR(
ref ia);Console.WriteLine(ia.baseaddr);
Console.WriteLine(ia.elsize);
Console.WriteLine(ia.offset);
Console.WriteLine(ia.bdefined);
Console.WriteLine(ia.rank);
Console.WriteLine(ia.extent1);
Console.WriteLine(ia.stride1);
Console.WriteLine(ia.lbound1);
Console.ReadLine();
int ival;UInt32 iadr;
unsafe{
int* ip;iadr=ia.baseaddr + ia.offset;
ip = (
int*)(ia.baseaddr + ia.offset); // point to first elementival = *ip;
Console.WriteLine(iadr);
Console.WriteLine(ival);
Console.ReadLine();
CsDllIntWrap.CSDLLINT( cname, cname.Length
ref isymcur,ref isymtmp,ref ndim,isize
ref ierr,cerr, cerr.Length);
Console.WriteLine(isymcur);
Console.WriteLine(isize[0,0]);
Console.WriteLine(isize[1,1]);
Console.WriteLine(cerr);
Console.ReadLine();
[StructLayout(LayoutKind.Sequential)]
public struct ra1_forptr{ public UInt32 baseaddr; public Int32 elsize; public UInt32 offset; public Int32 bdefined; public Int32 rank; public Int32 extent1; public Int32 stride1; public Int32 lbound1;}
public class CsDllIntWrap{
[DllImport("CSDLLINT.dll")]
public static extern void FORPTR( ref ra1_forptr iary);
public static extern void CSDLLCNAME(StringBuilder cname, int len_cname );[DllImport("CSDLLINT.dll")]
public static extern void CSDLLINT(StringBuilder cname, int len_cname,
ref int isymcur, ref int isymtyp, ref int ndim, [MarshalAs(UnmanagedType.LPArray)]
int[,] isize,
ref int ierr,StringBuilder cerr,
int len_cerr);}
----------------- Fortran ------------------!
! FUNCTIONS/SUBROUTINES exported from CSDLLINT.dll:
! CSDLLINT - subroutine
!DEC$ ATTRIBUTES DLLEXPORT::FORPTR
save
integer,pointer :: iary(:)
integer, allocatable, target :: iary1(:)
iary1=7
end
subroutine CSDLLINT(cname,isymcur,isymtyp,ndim,isize,ierr,cerr)
!DEC$ ATTRIBUTES DLLEXPORT::CSDLLINT
integer :: isymcur
integer :: isymtyp
integer :: ndim
integer :: isize(0:4)
integer :: ierr
character(len=*) :: cerr
cname=cx
isymtyp=2
ndim=3
isize(:)=4
ierr=5
cerr='Just a test'
print*,i,ichar(cname(i:i))
enddo
print*,len(cname),ichar(cname(30:30)),ichar(cname(31:31)),ichar(cname(32:32))
cname=cx
return
What is the best approach to output to the GUI several seperate lines? Can you get the editcontrol box (or whatever works) to display on seperate lines without creating a seperate box for each line? thanks.
Result x = X
result y = Y
The results to display could be longer than just "X & Y" if the user initially selected to calculate "A - Z". The results of the calculation are read-only to the user. The outputs from the calculation are reals and integers that are each converted to character strings for output to the GUI.
THANKS
SUBROUTINE CONSOLEDISPLAY(CHECKED) !***************************************************************************** !* * !* CALBACK SUBROUTINE TO BRING UP A DIALOG BOX TO DISPLAY THE CONTENTS OF THE* !* CONSOLE LOG FILE IN A LIST BOX * !***************************************************************************** USE DFLIB USE DFLOGM IMPLICIT NONE INCLUDE 'RESOURCE.FD' TYPE(DIALOG)DLG COMMON/CONSOLE/CONSOLEFILE CHARACTER($MAXPATH) CONSOLEFILE LOGICAL(KIND=4)RET INTEGER(KIND=4)IRET, I CHARACTER(LEN=130)CTEMP1 LOGICAL(KIND=4)CHECKED CALL UNUSEDQQ(CHECKED) !* INITIALIZE THE DIALOG BOX RET = DLGINIT(IDD_SHOWCONSOLE, DLG) RET = DLGSET(DLG, IDC_LIST_CONSOLE,250,DLG_NUMITEMS) OPEN(UNIT=200,FILE=CONSOLEFILE,STATUS='OLD', ERR=1000) I = 1 DO WHILE (.NOT. EOF(200)) READ(200,'(A130)')CTEMP1 I = I+1 RET = DLGSET(DLG, IDC_LIST_CONSOLE,CTEMP1,I) ! IF I EXCEEDS DLG_NUMITEMS, DLG_NUMITEMS IS AUTOMATICALLY INCREASED... END DO !* BRING UP THE DIALOG BOX IRET = DLGMODAL(DLG) !* EXIT BUTTON IF(IRET == IDC_CONSOLE_EXIT)THEN !* DESTROY AND RELEASE THE DIALOG RESOURCES CALL DLGUNINIT(DLG) ENDIF GO TO 999 1000 CONTINUE IRET = MESSAGEBOXQQ('ERROR OPENING CONSOLE LOG FILE'C,'ERROR'C,MB$ICONSTOP .OR. MB$OK) 999 CONTINUE REWIND(UNIT=200) CLOSE(UNIT=200) RETURN END SUBROUTINE CONSOLEDISPLAY
