29580 Discussions
C# Objects from Visual FORTRAN Console Program
David_Caruthers
I am new to this type of mixed mode programming so will need much help (or maybe not).
I is there a way to access a C# object that accesses a SQL Server database to retrieve program data from the database. The FORTRAN routine needs to retrieve data for a database object that is pointed to by program generated parameters.
There are multiple instances within the FORTAN legacy routines where external database data will be required to replace legacy FORTRAN direct access file lookup.
Thanks for any help! I don't design them just build then.
David
Jugoslav_Dujic
Valued Contributor II
