Sharing data via a module in a DLL
Ilie__Daniel
Hello!
The attached solution contains a module with two variables that are exported from a DLL and the main program, which should access these variables.
I cannot get the main program to build. I am probably doing something silly. Any help is greatly appreciated.
Daniel.
DavidWhite
Valued Contributor II
Daniel,
I beleive you misunderstand what DLLEXPORT does - this provides an entry point in the DLL for a routine to be accessed by the calling program. You cannot EXPORT a variable in this way.
Why do you want the Module in a DLL? You can build the app simply with the Module code in the main build.
David
IanH
What error message do you get/compiler version are you using/steps are you taking? Your example builds here...
I'm pretty sure DLLEXPORT on variables is "ok". As an operating system concept it is definitely supported (though perhaps discouraged - consider get/set procedures instead), and tests show it works with the compiler too.
DLLEXPORTing variables is fine. There is a worked example of doing exactly this in the sample DLL\DLL_Shared_Data installed with the compiler (unzip DLL.zip into a writable folder to use.) If it's a module variable, even better, as that will automatically turn into a DLLIMPORT. If you are sharing data between processes, you also need to set the data image section to RWS. See the sample for details.
Ilie__Daniel
Thank you all for your suggestions.
Steve,
I found the sample and adapted my code. The whole solution builds fine but I still cannot get my program to work properly.
The solution consists of two executables and one DLL. The "shared-data.exe" launches the "writer.exe", using RUNQQ. "writer.exe" updates the integer in the module. "shared-data.exe" prints the updated integer variable. The problem is that I cannot get past the RUNQQ statement: I get the following message from Windows:
writer.exe The application was unable to start correctly (0xc0000005).
The returned result from RUNQQ is 5.
I alsoget the following warning when I build the DLL:
LINK : warning LNK4092: shared writable section '.data' contains relocations; image may not run correctly
(DLL-BuildLog.htm is attached). But the output from DUMPBIN /HEADERS (dumpbin.txt) does not show any relocations for .data Section.
I have attached the source andthe builds.
I am running on Windows 7 64bit. IVF 9.1.039. VS2005
Any ideas?
