C Sharp Device
JohnNichols
Honored Contributor I
Dear Intel:
I am not sure if Steve is back, but I will assume not.
I have a device that is called by C# code and I am stuck with the access to the data stream through C#.
I have tried to get the Fortran calls C to add an extension to C#.
http://support.microsoft.com/kb/828736 (this contains an error in creating the SNK file link)
using this standard for calling C# from C++. I got this to work, and then I got the C++ translated into the Fortran calls C module, but then I have compile errors.
The problem is that you have to register the DLL, which can do, but once I include the C# call inside the C called from the Fortran routine I get strange errors.
I would appreciate your thoughts on what are my errors and faults in the code.
JMN
I realise that I can call the C# from the C++ and then call the Fortran, but I prefer not to unless forced.
jimdempseyatthecove
I am sure there is an easy way for you to eliminate the error...
Why not take the hard way....
Create a C++/C# application with no Fortran.
Create a Fortran application with noC++/C#
Have the Fortran Create(run) a process (your C++/C# application)
Connect the two in method of your choice
Memory Mapped File
Pipe
Messaging
Jim Dempsey
JohnNichols
Jim:
I considered that and thought let us be pure. Purity has its costs.
But I have been reading further, the problem was I was reading all the stuff on C# and Fortran on the web and not reading the Intel manual. the manual helped a lot once I got past all the guff.
I finally worked out what the Fortran wizard was and generated the following module to call the registered DLL I had made. However I have not seen the $object before, I need help calling the module routine, my stuff gives a crash.
[bash]! Console1.f90 ! ! FUNCTIONS: ! Console1 - Entry point of console application. ! !**************************************************************************** ! ! PROGRAM: Console1 ! ! PURPOSE: Entry point for the console application. ! !**************************************************************************** program Console1 use sManagedDLL implicit none Real ret INTEGER(INT_PTR_KIND()) $OBJECT ! Variables ! Body of Console1 print *, 'Hello World' ret = ICalculator_Add( $OBJECT, 2, 3) end program Console1 [/bash]
JMN
[bash]! sManagedDLL.f90 ! This module contains the Automation interfaces of the objects defined in ! B:UsersJohnDocumentsVisual Studio 2010ProjectssManagedDLLsManagedDLLbinDebugsManagedDLL.tlb ! Generated by the Fortran Module Wizard on 06/07/12 MODULE sManagedDLL USE IFWINTY USE IFAUTO IMPLICIT NONE ! CLSIDs TYPE (GUID), PARAMETER :: CLSID_Class1 = & GUID(#268EB429, #656C, #38F8, & CHAR('B1'X)//CHAR('37'X)//CHAR('C2'X)//CHAR('AA'X)// & CHAR('26'X)//CHAR('BA'X)//CHAR('DD'X)//CHAR('68'X)) TYPE (GUID), PARAMETER :: CLSID_ManagedClass = & GUID(#FABF2B8F, #5D04, #34E2, & CHAR('B1'X)//CHAR('2D'X)//CHAR('6D'X)//CHAR('C0'X)// & CHAR('10'X)//CHAR('D8'X)//CHAR('F3'X)//CHAR('08'X)) ! Module Procedures CONTAINS ! Error message routine SUBROUTINE $$DisplayError(invokeargs) USE USER32 IMPLICIT NONE ! Arguments INTEGER(4) invokeargs ! Error Variables INTEGER(2) code CHARACTER (LEN=256) :: source CHARACTER (LEN=1024) :: description CHARACTER (LEN=256) :: help_file INTEGER(4) help_context INTEGER(4) scode ! Local Variables CHARACTER (LEN=2048) ::msg CHARACTER (LEN=2048) ::msgtemp CHARACTER (LEN=1) ::lf INTEGER(4) ret lf = 'n'C ! Retrieve the error information CALL AUTOGETEXCEPTINFO (invokeargs, code, source, description, & help_file, help_context, scode) WRITE (msg, '(A, A, "Error code: 0x", Z8.8, A)') & TRIM(description), lf, scode, lf IF (source /= " ") THEN WRITE (msgtemp, '(A, "Source of error message: ", A, A)') & TRIM(msg), TRIM(source), lf msg = msgtemp END IF IF (help_file /= " ") THEN WRITE (msgtemp, '(A, "Help file: ", A, A)') & TRIM(msg), TRIM(help_file), lf msg = msgtemp END IF ! Display the message ret = MessageBox(NULL, TRIM(msg)//""C, "Automation Method Exception"C, & IOR(MB_ICONASTERISK , MB_OK)) END SUBROUTINE INTEGER(4) FUNCTION ICalculator_Add($OBJECT, Number1, Number2, $STATUS) !DEC$ ATTRIBUTES DLLEXPORT :: ICalculator_Add IMPLICIT NONE INTEGER(INT_PTR_KIND()), INTENT(IN) :: $OBJECT ! Object Pointer !DEC$ ATTRIBUTES VALUE :: $OBJECT INTEGER(4), INTENT(IN) :: Number1 !DEC$ ATTRIBUTES REFERENCE :: Number1 INTEGER(4), INTENT(IN) :: Number2 !DEC$ ATTRIBUTES REFERENCE :: Number2 INTEGER(4), INTENT(OUT), OPTIONAL :: $STATUS ! Method status !DEC$ ATTRIBUTES REFERENCE :: $STATUS INTEGER(4), VOLATILE :: $RETURN INTEGER(4) $$STATUS INTEGER(INT_PTR_KIND()) invokeargs invokeargs = AUTOALLOCATEINVOKEARGS() CALL AUTOADDARG(invokeargs, '$RETURN', $RETURN) CALL AUTOADDARG(invokeargs, '$ARG1', Number1) CALL AUTOADDARG(invokeargs, '$ARG2', Number2) $$STATUS = AUTOINVOKE($OBJECT, 1610743808, invokeargs) IF ($$STATUS == DISP_E_EXCEPTION) CALL $$DisplayError(invokeargs) IF (PRESENT($STATUS)) $STATUS = $$STATUS ICalculator_Add = $RETURN CALL AUTODEALLOCATEINVOKEARGS (invokeargs) END FUNCTION ICalculator_Add END MODULE [/bash]
JohnNichols
The C# Code is in the DLL is:
[bash]using System; using System.Collections.Generic; using System.Linq; using System.Text; namespace sManagedDLL { public class Class1 { } // Interface declaration. public interface ICalculator { int Add(int Number1, int Number2); }; // Interface implementation. public class ManagedClass : ICalculator { public int Add(int Number1, int Number2) { return Number1 + Number2; } } } [/bash]
JohnNichols
Dear Steve:
This complies but gives me an error
[bash]! Console1.f90 ! ! FUNCTIONS: ! Console1 - Entry point of console application. ! !**************************************************************************** ! ! PROGRAM: Console1 ! ! PURPOSE: Entry point for the console application. ! !**************************************************************************** program Console1 use IFCOM USE IFWINTY use sManagedDLL implicit none Real ret integer(4) status INTEGER(INT_PTR_KIND()) IA status = 111 ! Variables ! Body of Console1 print *, 'Hello World' write(*,*)status CALL COMCreateObjectByGUID (CLSID_Class1,CLSCTX_INPROC_SERVER,CLSID_ManagedClass,IA,status) write(*,*)status !ret = ICalculator_Add( IA, 2, 3) end program Console1 [/bash]
John,
I will defer to users who have experience with C# and COM - that doesn't include me. Please understand that this is a user forum. While I and other Intel engineers do participate, we can't promise to provide help with all "how to" questions.
I do recall, though, that you need to call COMInitialize before any other COM calls, and then COMUnInitialize at the end.
JohnNichols
Steve:
Thank you for your response. I fully appreciate your points, I was no where near as kind when I found out the device was accessed with C#. Unfortunately there are very few people in the world with Fortran and C# experience, anyone with anyengineering sensewould not access a device needing FFT analysis in C#, but I am stuck with it.
I need to compute a FFt every one second on multiple channels, which leaves Fortran or C++. I have FFT routines in C++ and Fortran, but I have tested the Fortran and I prefer stuff that has been properly proven to give the answer and not have to recalibrate the code.
I have slowly worked through the Intel Fortran manuals and actually I usually solve it by digging into the include files.
I have the code running albeit with some interesting errors, most I am sure I will solve,
But a question: what does warning 11077 mean? This is the C# routine I am trying to import, so why do I get a warning?
See below:
[bash]ipo: warning #11077: b:usersjohndocumentsvisual studio 2010ProjectsConsole1Console1DebugConsole1.obj: locally defined symbol __imp__SMANAGEDDLL_mp_ICALCULATOR_ADD imported 1> Creating library b:usersjohndocumentsvisual studio 2010ProjectsConsole1Console1DebugConsole1.lib and object b:usersjohndocumentsvisual studio 2010ProjectsConsole1Console1DebugConsole1.exp 1>Console1.obj : warning LNK4217: locally defined symbol _SMANAGEDDLL_mp_ICALCULATOR_ADD imported in function _MAIN__ 1>Embedding manifest...[/bash]
This warning, which is the same as LNK4217, means that you have done a DLLIMPORT (either explicitly or implicitly) of a symbol that is defined in your own code. It can be ignored.
If you are computing FFTs, have you considered calling Intel MKL?
JohnNichols
Steve:
In answer to your question: most probable route, I just do not like to fail, but until someone in Intel gives us a sample like this below I do not want to waste more time.
http://support.microsoft.com/kb/828736/c
Go and have a look at this microsoft sample, I have it running in C++ and C#. I would think it is not hard, as I have been trying to do in IVF. You have no samples from C# that I can find running.
The problem is down to two:
1. With the Fortran Module Wizard do I import all of the classes in the DLL or just the call to the routine I want to use.
2. this question depends on the answer to 1.
JMN
You should need to import only the routines you want to use. I will take a look at the article you describe, but I do not know C#.
JohnNichols
Steve:
I doubt this has anything to do with C#. I am making a mistake calling the Module created by the Intel Fortran Wizard.
Ifound this error which appears to be related:
There is a Statistics Package called R. It has a Fortran program to open R from Fortran. This program is shown at
http://rfortran.googlecode.com/svn-history/r21/trunk/src/RFortran_MedLevel.f90
The program includes acall to ComCreateObjectbyGUID just as I do below.
CALL COMCreateObjectByGUID (CLSID_Class1,CLSCTX_ALL,IID_ICalculator,IA,status)
write(*,*)IA
write(*,*)status
I get the same return error code as shown in the RProgram in Fortran.
[bash]! Initialise the COM Model call COMINITIALIZE(ok) if(ok/=0) then msg="COM architecture could not be initialised, ID:" // ok if(present(messOut))messOut=msg call message($error,msg); return end if ! Create call COMCREATEOBJECTBYGUID (rcom_CLSID_StatConnector, CLSCTX_ALL, IID_IStatConnector, R, ok) ! Create an instance of the R object if(ok/=0) then msg="Issue loading rcom.ID:"//ok selectcase(ok) case(-2147024732) ! strange bug with excessive commit stack size msg=trim(msg)//"(stack2big[commit]:reset<=450MB)" case(-2147024888) ! strange bug with excessive reserve stack size msg=trim(msg)//"(stack2big[reserve]:reset<=370MB)" case(-2147221164) ! happens if R did not have enough time to initialise msg=trim(msg)//"(R did not have time to open[increase'wait4R/wait4Rdef~5000'])" endselect if(present(messOut))messOut=msg call message($error,msg); return [/bash]
I get the message -2147221164, which is bizarre. RFortran is compiled on IVF as they include reference to the Intel Program.
So the problem is what is wrong with this call
to the following Fortran Module Wizard Code
[bash]! sManagedDLL.f90 ! This module contains the COM interfaces of the objects defined in ! B:UsersJohnDocumentsVisual Studio 2010ProjectssManagedDLLsManagedDLLbinDebugsManagedDLL.tlb ! Generated by the Fortran Module Wizard on 06/08/12 MODULE sManagedDLL USE IFWINTY USE IFCOM IMPLICIT NONE ! CLSIDs TYPE (GUID), PARAMETER :: CLSID_Class1 = & GUID(#268EB429, #656C, #38F8, & CHAR('B1'X)//CHAR('37'X)//CHAR('C2'X)//CHAR('AA'X)// & CHAR('26'X)//CHAR('BA'X)//CHAR('DD'X)//CHAR('68'X)) TYPE (GUID), PARAMETER :: CLSID_ManagedClass = & GUID(#FABF2B8F, #5D04, #34E2, & CHAR('B1'X)//CHAR('2D'X)//CHAR('6D'X)//CHAR('C0'X)// & CHAR('10'X)//CHAR('D8'X)//CHAR('F3'X)//CHAR('08'X)) ! IIDs TYPE (GUID), PARAMETER :: IID_ICalculator = & GUID(#E7CED320, #79C2, #3976, & CHAR('8D'X)//CHAR('2D'X)//CHAR('B9'X)//CHAR('4D'X)// & CHAR('B5'X)//CHAR('61'X)//CHAR('1C'X)//CHAR('C0'X)) ! Interfaces INTERFACE INTEGER(4) FUNCTION ICalculator_Add($OBJECT, Number1, Number2, pRetVal) INTEGER(INT_PTR_KIND()), INTENT(IN) :: $OBJECT ! Object Pointer !DEC$ ATTRIBUTES VALUE :: $OBJECT INTEGER(4), INTENT(IN) :: Number1 !DEC$ ATTRIBUTES VALUE :: Number1 INTEGER(4), INTENT(IN) :: Number2 !DEC$ ATTRIBUTES VALUE :: Number2 INTEGER(4), INTENT(OUT) :: pRetVal !DEC$ ATTRIBUTES REFERENCE :: pRetVal !DEC$ ATTRIBUTES STDCALL :: ICalculator_Add END FUNCTION ICalculator_Add END INTERFACE POINTER(ICalculator_Add_PTR, ICalculator_Add) ! routine pointer ! Module Procedures CONTAINS INTEGER(4) FUNCTION $ICalculator_Add($OBJECT, Number1, Number2, pRetVal) !DEC$ ATTRIBUTES DLLEXPORT :: $ICalculator_Add IMPLICIT NONE INTEGER(INT_PTR_KIND()), INTENT(IN) :: $OBJECT ! Object Pointer !DEC$ ATTRIBUTES VALUE :: $OBJECT INTEGER(4), INTENT(IN) :: Number1 !DEC$ ATTRIBUTES REFERENCE :: Number1 INTEGER(4), INTENT(IN) :: Number2 !DEC$ ATTRIBUTES REFERENCE :: Number2 INTEGER(4), INTENT(OUT) :: pRetVal !DEC$ ATTRIBUTES REFERENCE :: pRetVal INTEGER(4) $RETURN INTEGER(INT_PTR_KIND()) $VTBL ! Interface Function Table POINTER($VPTR, $VTBL) $VPTR = $OBJECT ! Interface Function Table $VPTR = $VTBL + 28 ! Add routine table offset ICalculator_Add_PTR = $VTBL write(*,*) 'Here' $RETURN = ICalculator_Add($OBJECT, Number1, Number2, pRetVal) $ICalculator_Add = $RETURN END FUNCTION $ICalculator_Add END MODULE [/bash]
